Peugeot 405 problem
Toby_HDi
x 3
Peugeot 405 problem
Unread post by Toby_HDi »
For a while now my sisters 405 has been playing up. Every so often it would start kangerooing, losing power, cutting out at junctions and revving itself up and down when the clutch was dipped. Other times it would run fine.
She had an auto electrician look at it and he said it was either a sensor or the coil pack. I had a suspicion it was the coil pack. She decided to bite the bullet and buy a coil pack for it and I fitted it this afternoon. Now when you start, it starts to idle roughly and like it will stop again. However, if you rev it slightly it settles down and idles nice and smoothly.
The coil pack seems to have made a difference but due to the issues starting I'm wondering if there could be another issue. Muck in the fuel? The fuel gauge does go up and down at times. I've suggested sticking in some V-Power and some injector cleaner and seeing if that makes a difference but I thought I'd throw it out here and see if there are any other suggestions. Its a lovely car, and seems a shame not to get it sorted.
Nearly forgot, it's the 1.6 XU5 petrol.
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
uncle buck
x 10
Unread post by uncle buck »
Its not the stepper motor is it?
I've had no experiance of a stepper motor problem but from what I've read they seem to cause the symptoms you describe when they go dodgy.
Maybe someone with more experiance of these things can advise.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
x 5683
Or a worn/dirty throttle pot?
x 94
Unread post by citronut »
i agree with uncle buck,
first port of call would be remove the stepper motor give it a blast out with carb cleaner, stick it back on if it runs fine now it will need a new stepper motor, as they dont like it up em (carb cleaner that is),
regards malcolm
Toby_HDi
x 3
The throttle position switch was actually replaced.
Am I to believe the stepper motor is a different thing? Where is this likely to be mounted on the XU5's throttle body?
Toby
Previous:
x 94
its a short round black canister shaped thingy held in place by two torx screws with a plug on the rear end,
if its got one that is
regards malcolm
Toby_HDi
x 3
Thought it was. I have cleaned it with carb cleaner in the past with no effect. Maybe its completely gone?
Toby
Previous:
Toby_HDi
x 3
Right, another go with the carb cleaner today. Cleaned the pushrod and the port in the throttle body.
Started it up and it cranked whilst pushing through the carb cleaner but then fired up with no throttle (usually had to give some throttle to get it to start) but it went u[p to 3k rpm and stayed there for a min or so before coming back down to 1.5k. I can't even move the pushrod of the motor with my fingers when it's off the car so I'm assuming its really sticky and gone completely.
Looks like a new one needed
Toby
Previous:
