hi all
i have a Citroen Xantia 2.1 td estate been driveing fine suspension was working well then had bad lhm leak from sink valve seal under lhm reservoir have removed and replaced seal now car will not rise to max on front .os staying appox in same position as before leak ns down very low have removed pipe from top of speher and started car no pressurer in line at normal height also when car put to full up position the back of car will go fully up os front stays in normall position but no oil flowing to ns pipe can any one help with this fault
replaced sink valve seal
citroenxm
- Fallen Hero
- x 70
