Me back end won't go down
CITROEN-SUCKER
Unread post by CITROEN-SUCKER »
Hi I have just taken my Height corrector to bits and successfully rebuilt it and to my suprise the thing seems to work fine very quick and responsive However I have noticed that the spring connector thing that attaches to the main control rod seems to be a bit weak. Moving the control inside the car to high the car responds at both ends same again for normal but when I set it to low only the front works. I have checked the rear corrector and it moves easily enough. has anyone else had a problem with the spring and is it easy / cheap to fix?
J.J.
P.S. 1994 Xantia 1.9 TD SX 164000 Miles
