Xantia Tailgate lock jammed
dwthia
Unread post by dwthia »
The tailgate has been jammed for 2 months - managed to open it yesterday and tried reapplying plastic membrane and dry out foam. Is there any way a manual line can be fixed to the locking mechanism to open it from the inside when I want to or do i need a new lock mechanism
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Is your Xantia a S2 model? If so you could fit a boot lock from a S1 which has a key slot to lock/unlock the boot.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
dwthia
I have the keylock - but it has never been used and despite wd40 it is jammed completely
lexi
x 133
Unread post by lexi »
Take the membrane off again. check and lube everything from inside the door where you can get a look at what`s happening. The usual problem with this model is that it will not lock on the remote first time.
What you have is a severe inconvenience.
If all fails it may be a new lock.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
dwthia
I have attached a wire to the locking mechanism and to date it opens every time.................
I think a new lock is the best bet with some warmer weather. Thanks for your help - will report back when fixed
Thommo
