megane electrical fault
spliffy
Unread post by spliffy »
i have a renault megane 1998 1.6 sport (ha ha not very sporty thou) it has an electrical fault when i indicate right the fog light light on dash flashes with it when i brake the indicator stops working until i release the brake when i have the lights on and brake it flashes fast has any one come across this before it sounds to me like a bad earth but where do i start looking before i rip the car to bits cheers
Spliffy
have owned : renault 21,mk1 megane 1.6 8v
currently own renault megane grand scenic ( 1.9 dci privelige )
currently own renault megane coupe 1.6 16v
uncle buck
x 10
Unread post by uncle buck »
Yeah that does sound like a bad earth connection.
I would start by looking at the right rear light cluster...make sure to clean all of the connections to the cluster & to remove & check that all of the bulbs are working & have no corrosion on them.
Hope you find the problem.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
spliffy
cheers buck i will try that when we are not ankle deep in snow
Spliffy
spliffy
ok now
cheers problem seems sorted i cleaned both connections on the light cluster and the plug and eveything seems to work ok now
Spliffy
uncle buck
x 10
Excellent...glad you are sorted.... :D
Bad Earths can throw up all sorts of problems...some of which you wouldn't expect....always wise to make sure all bulbs are working properly & that the connections are nice & clean.
Cheers.
