Hydraulic pipe flaring tool hire?
rmcdonal
Unread post by rmcdonal »
Hello, does anyone know of a garage/specialist/friend who could rent the flaring tool for the Citroen hydraulic pipes?
I've got a corroded front to rear pipe (Xantia II 110hdi estate) and it looks a bit of a nightmare to access and change at the front. I've already purchased the replacement pipe/seals and I believe GSF can supply the union joints, but I'm stuck for the specific citroen flaring tool and find £200 a tad expensive for the tool especially when its only for a one off pipe.
Any help or advise is very much appreciated!
Thank you...........
x 8394
Give Martin at Pleiades a call. He should be able to help...
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
You be lucky, I asked the same question and no one could help.. Think Im gonna have to invest in two tools from Plieades, 3.5 and the bigger one...
Cant afford the big expensive one that ebay have listed.
Paul
A very sad...
1994 XM 2.1 d auto
rmcdonal
CitreonXm and CitroJim, thanks guys. I've looked through other posts and found Pleiades phone number. Not sure if they're open between xmas and new year but will give them a go.
Thanks again for you responses........
1994 Xantia 1.9D LX
1998 Xantia 3.0L V6
2000 Xantia 110 HDi estate
meexi
Unread post by meexi »
the problem with the one off ebay is that it is difficult to use under the car while the one from martin is perfect for the job and easy to use the only problem we had was on the original steel pipe as it needs a really good grip of the pipe
2004 C3 XTR HDI 16V 92bhp
2004 Xsara Picasso Exclusive HDI 16V 110bhp
1989 Peugeot J5 Hymer B694 2.5td intercooled 8v 96bhp
x 94
Unread post by citronut »
meexi wrote
"the only problem we had was on the original steel pipe"
i find exactly the same problem with the small hand held tool i have for the 3.5mm pipes,
cant repeatedly make a nice swage on steel pipes,
but on copper knicle a good job every time,
regards malcolm
meexi
i agree the copper nickel are amazingly easy you just have to remember to put the nut on and on the correct way :lol: :lol:
i have the pictures of my dads XM that we did but have to sort them out and write a blog :)
hdirob
Unread post by hdirob »
i had the tool from martin for the 3.5mm pipe and it works a treat ... just remember to clean the old pipe on car of the plastic coating thats on it and the tool works a treat.
speak to martin he supplied me with everything i needed and was very helpful.
Rob
