Rust removal
Yes, place your time and money saving tips here.Nothing illegal or dangerous please!Motoring related only please.
lexi
x 133
Rust removal
Unread post by lexi »
This is a handy method for objects that will come off the car.
Take a PLASTIC bucket with enough water to cover the object. Throw in a couple of tablespoons of Washing Soda. Take a battery charger. Put Neg terminal onto the objectbeing cleaned. This will be the Cathode. The Positive goes to a bit of scrap mild steel..this is Anode. Make sure they have space to not touch in bucket.
Turn on and leave for 24 hrs. The Anode ends up with the rust and gunge attracted to it.
You can experiment with different size Anodes and time in bath for best results.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Brigsygtt
Unread post by Brigsygtt »
Looks good ill have to try it 8)
Soaking small parts in vinegar works ok too.
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
x 8406
Good stuff Lexi :D Inspired!
You may get even better results if you use zinc as the anode as it has a different electropotential to steel.
This is the same idea behind the use of sacrificial anodes on the hulls of boats to protect them against rust.
colinxm
Unread post by colinxm »
Hi Lexi, nice tip - thanks !
One question though, what is Washing Soda ?
Cheers Colin.P
1995 Cit XM 2,1 TD Silver Estate
2004 Pug 307 SW
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
TopDonkey
Unread post by TopDonkey »
I've soaked really rusty parts and even tools in vinegar (i think it has to be the clear vinegar), and they come up spotless after a day or 2, i usually have a big pot of vinegar in my garage to drop parts into if i need to do any derusting, just make sure you have an airtight lid on it as it really stinks !
lexi
x 133
It`s Sodium Carbonate Colin.
The advantage to this method is that none of the metal is eaten (as with acids) .......ONLY the rust. It is used by Horologists on tiny parts that cannot stand acid or abrasion.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
