sx spehres vs. hydractive soft mode
deian
Unread post by deian »
hi,
was over at pauls today and i saw how soft the rear of this xantia sx was, lovely and fluffy comes to mind, anyway, he says normal sx spheres are softer than hydractive when in soft mode, so to get the hydractive as soft as possible would it be nice to put sx spheres on, or is it a silly idea?
thx
DickieG
Monaco's youngest playboy
x 33
Re: sx spehres vs. hydractive soft mode
Unread post by DickieG »
deian wrote:hi,
Hydractive in soft mode is softer than standard Hydroneumatic but for an even sofer ride fit non Hydractive sphere's to a Hydractive car, sooo soft, I've been enjoying the soo smooth ride on my HDi for 110 miles today, comfort personified :D :D
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
deian
Pauls one is VERY soft, and I doubt he's put hydractive ones one, that would make it harder, we'll see how I go anyway, cos my backend isn't as soft as the front. I'll see how I feel after my fix. I'll keep you posted richard.
How is the handling in hard mode compared to how a hard mode would be with the proper spheres?
Thx
vince
x 13
Unread post by vince »
DickieG wrote:
deian wrote:hi,
Hi Richard...i need to change my rear spheres pretty soon and was going to follow suit and do the rear corners with non hydractives.
But...when we spoke about it at the national rally, did you say it can bottom out on the rear ? and if so under what conditions?
DickieG
x 33
vince wrote:Hi Richard...i need to change my rear spheres pretty soon and was going to follow suit and do the rear corners with non hydractives.
If you have a full load and are travelling over an undulating road surface, in such instances I put the suspension into sports mode which addresses it. When in sports mode pretty much any degree of steering, braking or compressing of the suspension switches the suspension into firm mode.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
vince
x 13
Great, a perfect solution..... :D
Non hydractive rears...here we come :P
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Not sure if DG is talking about his break or the V6.
Wagons have a 40mm rear cylinder bore, compared to the saloon's 30mm. That's 1250mm² vs 700mm² which is what (I reckon) makes an unladen break tend to be a little "crashy".
x 8395
addo wrote: which is what (I reckon) makes an unladen break tend to be a little "crashy".
Yes, very possibly Adam. They do ride a lot better when well loaded...
DickieG
x 33
addo wrote:Not sure if DG is talking about his break or the V6.
I have non hydractive sphere's on my HDi estate and my VSX TD saloon, the V6 run's with standard Hydractive sphere's, both the saloon and estate can suffer with poor damping if fully loaded on an undulating road's which is when I switch to sports mode. As for the vast majority of time I drive alone in the car this isn't a problem.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
deian
so would you say it could become 'overly' soft if i put standard spheres on a hydractive car when fully laden?? i.e it will just wallow like marshmallow
i would like a cushiony ride in comfort mode, and a little bit softer than what i get now on hard mode without making people sick in the back, only very often i get a full car, 4 ppl at the most when i am taxi to my sister and her toddlers, and sometimes 3 adults.
i've been looking at the sphere table on old-guy site and i'm wondering whether to just put hydractive estate spheres on my saloon rather than standard sphere and put standard on my front?
vince
x 13
It seems Dei that if you run a Hydractive saloon then you dont need to experience any rear end grounding out as you can manually select Hydractive and avoid it :wink:
Ive ridden in Richard's VSX, it is well worth switching to non hydractive's on the 4 corners....ive had my fronts on non hydractives for a while now and it transformed the ride for the better 8)
DickieG
x 33
Vince has got it right, the only proviso I put on using non Hydractive sphere's on a Hydractive car is to think about how you use the car, i.e. Do you carry a full load more often than not and do you regularly drive the car quickly, if that's the case then stick with the standard set-up.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
