help diagnosing v6 pump noise
citrov6
I think the bearings have gone on the hydraulic pump. It started whining 20 miles into a long journey, after 200 miles it turned into a scrapping metallic sound. It comes from front drivers side of the engine where the pump is though I suppose it could be anything in that area I find it hard to pin point it since the pump is still doing its job of raising the car. It did seem quiet before raising the car but that could be my imagination. Just want to confirm or not, what the problem is before replacing every single part until the sound goes
Love my black v6 xant - only one with cream coloured leather too!
- x 1240
lexi
- x 133
Use WD 40 with the long straw and put some at your suspect areas.......don`t overdo it on the belt and clean it off when engine stopped. May be tensioner or bearing. Change of noise can help detect the problem area. With any method be wary of that belt.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
citrov6
It seems to have gone quiet now, I let it warm back up but nothing. I'll take it out for a drive later and see if it starts again. Trying to avoid getting stuck in snow and dark at the moment.
Thanks for the test ideas I found a stethoscope I used a few years ago when there was another noise
Brigsygtt
citrov6
Stempy
The tensioner rollers can also get very noisey.
Lexia ponce
Lexia ponce
citroenxm
- Fallen Hero
- x 70
Altinator Bearings too, I had a similar noise on a TD VSX Estate with Air con, I swapped pumps being rather confident with the Screw Driver Listening test it ws the pump..
Um... nope ............ Turned out to be the Altinator bearings were shot! Amazingly loud rough noise..
I dont think the Ump has a bearing does it? Its a Brass Cap/seal bearing isnt it?
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
