buzzing noise
mikey_mike
buzzing noise
Unread post by mikey_mike »
hi all
2002 c5 estate , problem is a buzzing noise coming from drivers side rear wheel arch, something like a relay sticking, cant see anything amiss, wondered if any of you techie types would have a clue what is. it's not very loud and happens even when the car is switched off and locked.
mike
addo
Sara Watson's Stalker
x 95
Unread post by addo »
At a wild guess, the electric pump for ride height correction.
x 5671
And if it is, then there is a fault, should be inactive with the car locked.
See this thread (no conclusion yet though).
DickieG
Monaco's youngest playboy
x 33
Unread post by DickieG »
Is the noise inside or out? My HDi is fitted with a towbar which has the additional socket for charging a fridge etc when pulling a caravan, just after turning off I can hear a relay clicking on and off for a while. I investigated where the noise was coming from (O/S/R) and discovered a relay box of tricks associated with the auxiliary socket so left it alone.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
mikey_mike
Re: buzzing noise
mikey_mike wrote:hi all
mike
Gee thanx folks for quick replies. went out this morning looked behind the panel with the 12v socket and height switch and found the indicator relay for towing i removed the fuse all well now.
happy crimbo.
mike
2004 C5 2.2 HDi Exclusive Estate
