window problems .. all round
davetherave
x 4
Unread post by davetherave »
Anyone have any wiring diagrams for the citroen xm wiring for the drivers side window?
I am converting the 9 pin to 2 pin motor and so far failing.
cheers
Dave
(95) XM Silver 2.1td Exclusive.
(87) Cx 2.5 DTR T1 undergoing major cosmetic surgery.
GPZ500s
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
If you suceed Dave, you'll have the majoirty of S2 owners after you, as the S2 cables I think arent as strong as S1 cars, and fail a lot..
I assume you mean the winder has the anti pinch ECU built onto it..
Are they the same unit as the S2 Xantias?
Paul
A very sad...
1994 XM 2.1 d auto
davetherave
x 4
I dont think the winder has the anti pinch on it, the old 9 pin did, THe 2 pin has a seperate control box that does the anti pinch i think- either that or i have lost anti pinch!
I have just got the rear windows working by re connecting the passenger side control box, but still no power going to the passenger window :?
GPZ500s
x 1240
Unread post by Peter.N. »
Have you checked/changed all the switches, including those in the centre console, as they are in series, they will stop each other working.
davetherave
x 4
Sucess of sorts...
I now have three windows working rather than zero!
Rear and passenger work.
I think either i have blown up the drivers control box or i havnt done the wiring properly, think both are equaly likley. Just need the diagram then ill know.
The window was operating fine before i removed it from the donor car.
GPZ500s
xmexclusive
Unread post by xmexclusive »
Hi Dave
The wiring diagram in the BOL covers it completely.
Identical wiring for Mk1 XM's and SX Mk2's.
The drivers door switch is a 6 pin passing contact switch. The control
box electronics then switches the winder motor feeds on and off.
The high current 12V supply for the winder motor has to go direct to the control box not via the switch.
The 12V to the drivers door window switch just runs the switch illumination bulbs so is not essential for things to work.
All the other winder switches actually switch the high current 12V feed to the winder motor.
With your mods one touch should still work but you lose anti-pinch.
John
Xmexclusive
davetherave
x 4
Cheers John,
I just cant seem to get the box to output the 12v, i will have another crack at it tomorrow and report back... hopefully with more good news!
Next major job is the ABS, not looking forward to that one!
GPZ500s
