where is the ECU connector on a C5 RHD
citrokid
Unread post by citrokid »
Can any one tell me wher the ECU connector is on 2005 C5 i have looked under the steering wheel and connot see it , I have not pulled off any padding covers
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
What ECU connector are you looking for? i.e.engine, airbags etc
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
x 1942
Unread post by Paul-R »
If you're looking for the connector to read the ECU with a Lexia (or similar) then this is in the glovebox, with the fuses, behind a small panel.
citrokid
Paul-R wrote:If you're looking for the connector to read the ECU with a Lexia (or similar) then this is in the glovebox, with the fuses, behind a small panel.
does this connector then communicate with all the ecu's.
how many ecu's have the C5 got ?.
x 1056
Unread post by wheeler »
All the ECU's can be read from here. I can think of at least 22 ECU's off hand on a 2005 C5 (depending on what spec the car is).
citrokid
wheeler wrote:All the ECU's can be read from here. I can think of at least 22 ECU's off hand on a 2005 C5 (depending on what spec the car is).
found the connector, thanks
i am thinking about getting the lexia kit, any advise ?
Citroenmad
x 110
Unread post by Citroenmad »
The little diagnostic plug your meaning?
If anyone else is wanting to know, its in the glovebox behind the fuse box cover. Pull off the peice of trim with the little pocket attached and its just behind there.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
