Just about to leave. Car has been magnificent all week. Just get in it to go to supermarkt and the coolant light and STOP came on with beeping. Has come on again. CAn't bl00dy believe it. Just about to set off.
I suspect the guy selling the car put some water into the coolant and it is cold here. Could that be the reason for the warning?
ANSWER/Reassurance NEEDED ASAP!!!!!!!!!!!!!!!!!
URGENT
DickieG
- Monaco's youngest playboy
- x 38
DickieG
- x 38
citroenxm
- Fallen Hero
- x 70
BEEEPING
Not heard then beep before, Ive an ongoing fault with the Flashing STOP and the RED light on the coolant guage, Tried a new lever sensor, but not cured it, Level is fine, so Dont tend to listen to it.. (For Now)
Paul
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
boristhespie
- x 4
DickieG
- x 38
If it is low you can use water provided you're not seriously diluting the anti-freeze mix, a simple and crude method for checking if you have some anti freeze in there is to rub some coolant between your finger and thumb, it should feel greasy.boristhespie wrote:I was thinking that (freezing) as the heat guage is stuck to the left of the dial for a while.
And if it is low, what do I do? It's late no access to any c5 Citroen dealer. Is this stuff available from large supermarkets/halfords?
Before topping it up with any old sort of anti-freeze you really need to know what type is in there first to ensure they match.
Funnily enough just yesterday a neighbour/good friend called round yesterday in a panic about her VW Polo doing the very same thing as you describe, all it need was a small cup of water to top it up.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
boristhespie
- x 4
I have no way of knowing what type of antifreeze is in it. I know it has been serviced by Citroen all the time so I guess dealer stuff for a C5 HDi?
Got a Small Halfords here may pop down just in case. Don't want this thing freezing and bursting my engine.
CHECKED LEVEL WAY WAY LOW! BUGGER.
C'est pas possible!
boristhespie
- x 4
- x 5674
