Xantia heated seat.
trooper30
Xantia heated seat.
Unread post by trooper30 »
Alright fellas festive greeting and all that. And with it getting cold i am gonna have a look at my heated seat that doesnt work :(
The car is an exclusive so its all leather and the passenger seat heats up lovely, but nowt on the drivers seat. So i was wonderin if any of you guys had experience with this? Could it just be a case of checking a fues or checking a connection?
Cheers fellas
DickieG
Monaco's youngest playboy
x 38
Unread post by DickieG »
Its normally due to a break in the heating elements within the base of the seat, unfortunately the element pad is attached to the leather seat base so replacing them is somewhat expensive.
Finding a working drivers heated seat is rather rare but there are some around which have survived beyond 100k miles such as the one in Jim's Activa.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
colinxm
Unread post by colinxm »
I fixed both front seats on my xm by stripping the covers off (also leather) and soldering in a short length of wire to the broken section(s) of the heater elements. A long winded and tricky operation but has lasted a couple of years now and didn't cost anything more than a pack of cable ties :D
More info if you want it - just ask.
Colin.P
1995 Cit XM 2,1 TD Silver Estate
2004 Pug 307 SW
1989 Pug 205 Cabriolet
1998 Ford Puma
1979 Triumph TR7
DickieG
x 38
colinxm wrote:I fixed both front seats on my xm by stripping the covers off (also leather) and soldering in a short length of wire to the broken section(s) of the heater elements. A long winded and tricky operation but has lasted a couple of years now and didn't cost anything more than a pack of cable ties :D
If you would I'd be obliged as my HDi is a little chilly on the nether regions at the mo!
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
HDI
x 7
Unread post by HDI »
Mine only work on the highest setting , nothing on the first 2 , on both seats. Would that be elements or is there a power controller to them ?
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
x 8181
Yes, there is a power controller ECU buried in the seat somewhere. If it will help, I can supply wiring diagrams but it only shows the ECU as a box.
Shout if you want the diagrams HDI...
HDI
x 7
Superb , yes thanks mate !! There is no ref to heated seats in the BOL so this will be an immense help.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 8181
No worries, I'll warm up the scanner...
Be back in a bit..
DickieG
x 38
The ecu controller box is under the seat.
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
x 8181
Here's the diagrams HDI.
Sorry about the quality. MK2 diagrams are printed on tissue paper and the seat ones are in the back of the book and hard to keep flat :twisted:
Schematic Circuit
Harnesses
Locations
Looks like there is only one element in the seat and a temperature sensor.
Hope these help fix the problem...
HDI
x 7
Cheers , thats great . Should keep me busy for a while !
Looks like there is an element in the back and base of the seat. Can't recall if I can feel heat in the back , I'll check next time I use them , which will probably be tomorrow by the look of the outside temp tonight. Almost -3 here already.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Colin.P
Ah Colin, theres a difference, IF IM CORRECT, in that the XM elements are seperate to the Seat trim, were as, on the Xantia, its a little more embedded, I think also later S2 XM's are embedded a bit deeper.. unless im getting that mixed up with S1 XM elements..
Paul
A very sad...
1994 XM 2.1 d auto
xmexclusive
Unread post by xmexclusive »
Hi Paul
Series 1 XM's have the heater element fabric sheet glued to the seat cushion.
Series 2 XM's have a seperate heater element.
Both are a pain to remove and repair the broken element wires.
Because of the seperate sheet the Mk2 is slightly easier to do but they counteract this little gain by using a 3 stage heat controller and switch which gives far more trouble than the simple Mk1 switch control.
John
Xmexclusive
HDI
x 7
Reminds me of what an old friend was always telling me when I was younger and got all excited about the latest car or bike. I'd point out all the gadgets and new features and he would say "dunno why your getting all worked up over this stuff , it's just more that will go wrong ! "
I used to think he was just a cynical old sod but time has proven him to be right :wink:
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
citroenxm
Fallen Hero
x 70
xmexclusive wrote:Hi Paul
John
Thought I was wrong and a long way out.... :oops:
Paul
A very sad...
1994 XM 2.1 d auto
