Hi
Im wondering if anyone can help me. My V6 has her her a new set of Plugs, but prior to this my inlet manifold has been on off about 5 times, so basically I am after a NEW inlet manifold gasket.
Been to local dealer, but of course its on back order.. or they cant be bothered as they've not given me a delivery date.
So Im wondering, would anyone be willing to goto their local stealer and see if they either have one in stock or can get one next day.. my girl REALLY needs one, as shes a sod when cold missing.. but fine when warm/hot, ive checked all possible vaccuumm holes etc etc, all are ok so it can only be the gasket.
Car: 1997 P reg, V6 24v. P279PRW
Thanks guys. If two of you come back Ill buy both, so it wont be a wasted trip for anyone.
Regards
Paul
Any fellow V6 Xantia Drivers willing to help me??
citroenxm
- Fallen Hero
- x 70
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DickieG
- Monaco's youngest playboy
- x 38
A slight problem with your request (in that I presume you'll want it posted to you) is that the card the gasket is packaged in is about 2' x 2', I kid you not. As the gasket is very slim and fragile it won't be the easiest to safely package to ensure it arrives to you unbent. I do have one of these in stock now, I'm just rather concerned as to how to get it to you.
25 Jeep Renegade Trailhawk
23 BMW iX3 M Sport Pro
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
72 DS 21 EFi Pallas BVH
23 Jeep Avenger
13 Ram 1500 Hemi
06 C3 Desire 1.4
KP
- x 27
- x 8391
citroenxm
- Fallen Hero
- x 70
Back it onto some Wood! Ill be paying the sensible postage charge anyway, rather a bit more cost then months waiting and loads on fuel with a missing plug!DickieG wrote:A slight problem with your request (in that I presume you'll want it posted to you) is that the card the gasket is packaged in is about 2' x 2', I kid you not. As the gasket is very slim and fragile it won't be the easiest to safely package to ensure it arrives to you unbent. I do have one of these in stock now, I'm just rather concerned as to how to get it to you.
Chers DickieG
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
DHallworth
- x 167
Sid_the_Squid
Paul, mine had this exact same problem, every time I started the car in the cold weather she would be lumpy until the water temp reached 60C, I too suspected an air leak. However adding a can of injector cleaner* to my tank has solved the problem. its been over a month (and two tanks of fuel**) and no more lumpy when cold issues.as shes a sod when cold missing.. but fine when warm/hot,
Of course might not be the same problem, but its a cheap easy thing to try as a first point of action.
*I believe it was a bottle of Redex petrol injector cleaner.
**I'm not using the V6 regularly at the moment
Gone to the dark side.
Past Citroens
'99 Xantia HDi Exclusive
'99 Xantia 3.0 V6 Exclusive (Green Goblin)
'02 C5 Hdi 110 LX Estate
'98 Xantia 1.8 sx auto with LPG
'00 Xantia Hdi (110) forte
'97 Xantia 1.9D sx
'93 Xantia 1.9D lx (my first) R.I.P
Past Citroens
'97 Xantia 1.9D sx
citroenxm
- Fallen Hero
- x 70
Sid,
Shes not Lumpy, she runs on 5! A defenate Plug out miss, but fine when warm and the meatal has all expanded and sealed the "Gap" properly..
I can of injector cleaner may very well do the job! Thanks Sid, ill try some, wont hurt her after a shart while standing
Regards
Paul
Regards
Paul
A very sad...
1994 XM 2.1 d auto
A very sad...
1994 XM 2.1 d auto
