Speed Signal on a C5 SX Wagon HDi (2003)
trevor104
Unread post by trevor104 »
Hi can anybody help? I have to install a GPS/Electronic Distance Recorder to a 2003 Citroen C5 SX HDi Wagon, and need to know where I can pick up a clean speed signal or if I use a Cambus Converter when I need to attach it. Thanks Trevor 104
x 1056
Unread post by wheeler »
You can pick up a speed pulse from interconnector IC01 which is a 6 pin gray connector near the BSI. Pin number 1 which is wire number 6739.
trevor104
Thank you very much Wheeler. Regards Trevor104
