306 dt sport eletric window
scottishpaul
Unread post by scottishpaul »
the passenger window my car will go down but lost power for returning back to being closed ,im thinking relay has burned out had to remove the door trim and run power wire to close the window ,anyone know where the relay for the window is ? :?
pug 306 -turbo d 1993 -2001 xantia hdi 90 bhp -2000 partner van 2.0 hdi 90bhp
treky9.9
Unread post by treky9.9 »
Try stripping the switch and giving the electrical contact a good clean.
I had the same problem with my 306. I was quite surprised at the carbon build up in them.
Failing that, I would check the electrical contacts in the door plugs.
AndersDK
Unread post by AndersDK »
The relay is common to both sides EW's.
A separate relay is fitted for rear EW's.
These relays are simply used as circuit breakers to power the EW's, such that only the weak control current for the relay coils have to flow through the ignition switch contact set.
Anders (DK) - '90 BX16Image
