Radiator fans coming on
rmunns
x 9
Unread post by rmunns »
Year 2000 Hdi90 manual box. 44000miles. Temperature gauge runs just under an indicated 90degrees but, from cold, it takes 3 miles or so before the gauge gets up. Even at this time of year, the radiator fans come on more-than occasionally.
For certain thermostat hasn't ever been replaced. Should I?
x 1487
Have you got te direction set to demist? This puts the A/C on and hence the rad fans on, regardless of the postion of the A/C switch.... :wink:
rmunns
x 9
Richard, you're right. I had the aircon 'on' when I arrived home tonight.
I am assuming that when you put the controls to 'demist', the aircon switch light doesn't come on, only if aircon switch is depressed?
Sl4yer
Unread post by Sl4yer »
rmunns wrote:I am assuming that when you put the controls to 'demist', the aircon switch light doesn't come on, only if aircon switch is depressed?
That's correct!
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
