Turbo Gone ?
pikecrazy
Turbo Gone ?
Unread post by pikecrazy »
Lost power today on motorway :(
No warning lights , just no whine from the turbo and a bit of black smoke.
Still runs ok but no power :evil:
Any pointers ...............
Oh and its the 90bhp Dispatch hdi van
2013 Berlingo Multispace 1.6 XTR 115bhp
2003 2:0 HDI Dispatch Van 186000 miles......gone
2000 Xantia Hdi 90bhp Forte Estate 97000 miles gone..........to heaven
New High pressure Fuel Pump and Patched ECU , Blower Module fixed by CitroJim :-)
x 8386
Whilst I don't know about HDIs specifically, that sounds nothing like a failed turbo to me. I'd say it's more likely a pipe has popped off somewhere 'twixt turbo and engine somewhere, either that or it's split.
Did a variant of this engine have a bit of a reputation for splitting turbo pipes?
Old-Guy
x 24
Unread post by Old-Guy »
No turbo whine sounds ominous, but:
Turbo failure always (almost) means shot bearings = chewed oil seals = oil pouring down the exhaust pipe. So if it's now using loads of oil - sorry mate the turbo's probably gone.
If not:
How does the waste gate operate? Could all the exhaust gas be by-passing the turbo.
It's worth checking all the pipery from the turbo to the inlet manifold just to make sure a joint hasn't blown off (clip not done up last time?). Then check that inter-cooler (is there one?) hasn't got a hole in it (corrosion or something through the grill?).
Here's hoping it's simple and cheap :wink:
pikecrazy
Problem is cant really see or get to the turbo :evil:
pikecrazy
Ok turbo has blown :cry: and it looks like about 7hrs of labour charge :?
Deanxm
x 87
Unread post by Deanxm »
Same thing happened to my trany, made a very slight graunchy sound at high revs for a few minutes then the turbo siezed solid, turned out that the oil feed filter cartridge (like the ones you get pushed into the mating surface of the head on XU's for the valve gear) blocked, this starved the turbo and they dont last two minutes without oil, it done the same thing too, with no boost and a solid turbine restricting the exhaust it overfueled like mad belching thich black smoke and not having enough power to do over 20mph tops made getting to work fun.
D
XM Prestige PRV6 92
Mitsubishi L200 Trojan 14
