Air Con question
Post your Cit/Peu/Ren air conditioning queries or advice.
johnh2000
Air Con question
Unread post by johnh2000 »
Hi everyone
I have just purchased a Xsara Picasso 2 HDi with Climate Control. This is my first car with air con, I have a very basic question, should the system heat as well as cool? During the cold spell we have just had the heater seemed to warm at about the same speed as a non air con car (about 10 minutes). Clearing the front screen condensation took about 10 minutes as well.
Is this about right or is the air con in need of a service?
Thanks in advance
John
Xsara Picasso 2HDI
HDI
x 7
Unread post by HDI »
Yes , aircon heats as well as cools , in fact from a cold start aircon heats up the interior much quicker than the engine will. Also , demisting with aircon should be very quick.
May need a re-gas.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
johnh2000
Thanks for that, I apreciate you rapid responce.
John
Xsara Picasso 2HDI
x 1938
Unread post by Paul-R »
Yes, a screenful of condensation (not frost) should clear in a minute or so with aircon on.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
In fact a good working system will demist a WHOLE CAR in moments!!
Tried it in dads 206 HDi, it was all steamed up, so I switched it on, and with in moments it was all clear, heater was on warm too, its because it acts as two things, Air Con cooler for summer and also a De Humidifier / Air Dryer other times, even with the heater on warm, as the in comming air ALWAYS passes over the Air Con Evaporator behind the dash, air con on or not...
Paul
A very sad...
1994 XM 2.1 d auto
