C5 rear suspension strut
Duracell
Unread post by Duracell »
My 2003 C5 has just passed an MOT, but with an advisory that the N/S/R suspension strut is leaking and needs replacing - haven't had a chance to look at it yet but wondered if anybody has changed one of these. I've done one on a BX before but understand the C5 is different and I'm not sure about depressurising the hydraulics. Any advice appreciated.
x 94
Unread post by citronut »
i havent done a C5 one yet, but i would check the strut boot and sphere joint first,
regards malcolm
x 5678
Make sure it is the strut! They are designed to leak :)
What is far more likely is that the gaiter enclosing it is leaking.
The gaiter receives the leaking fluid and as it flexes pumps it back into the reservoir.
A new gaiter is around £12, a strut considerably more.
x 94
neh neh na neh neh,
beet yu Steve
regards malcolm
x 5678
citronut wrote:neh neh na neh neh,
beet yu Steve
regards malcolm
IR2 slow typing - I blame my daughter coming and interrupting me :)
Duracell
I'll have a good look at it before I do anything but the MOT was done by my local Citroen main dealer (taking advantage of their £27 MOT offer) and the tester told me that this is not unusual on the early C5's - If I find its a simple sphere joint leak or something similar it won't look good
viorelovidiu
Unread post by viorelovidiu »
hello
tomorrow in the morning i`ll reach a service to check suspension for sinkin down over night without any visible leak on the ground.
like you i suspect one of these struts!
I`ll post more informations tomorrow :roll:
Citroen C5 2005 2.2 HDI 136cp Exclusive BVA
EX: Citroen C5 2005 2.0 HDI 138cp Exclusive
EX: Citroen C5 2005 2.0i 143cp SX
x 94
just because a main dealer says its the strut leaking and its not unusual, they are there to take your dosh
regards malcolm
Duracell
I'd normally agree with you Malcolm but unfortunatly after looking at it this morning they may be right. The cylinder, gator and sphere are all completely dry but there is fluid discharging from the vent pipe on the gator into the cross beam and seeping out through the hydraulic block fixing bolts in the middle - I assume it shouldn't do that - is there any other reason it might be venting apart from a faulty cylinder?
x 5678
Fluid should go back to the reservoir via the return pipe (from the gaiter) Has this detached or become blocked?
Duracell
There is the normal return pipe from the gator but also a vent pipe which goes up into the hollow cross beam via a rubber grommet - it is open ended and is not attached to anything - the return pipe appears not to be blocked - there is no sign of fluid from the off side vent pipe but suspension movement produces fluid out of the near side
x 94
dose fluid come out of the trickle return pipe as well if you unplug it from the gaitor,
sounds like you presure seals in the susp unit/strut might be allowing more fluid passed that they should,
if you send me you chassis No. i will check on service citroen if all the seal and components are avalible indavidualy,
ps.
what mileage has the car done
regards malcolm
Duracell
There is certainly fluid in the return line but doesn't seem to be an exessive amount - car has only done 69,000 - have sent a PM with the chassis no - thanks for the help
x 94
i have returned a pm with a long list of part No.'s and price's,
but it would not accept your VIN No. saying there should be some spaces in it,
also it would not give me price's for estate seals at the mow, i will try later
regards malcolm
x 94
ps.
i thought i would copy and past the list here to
this list is part No.'s for saloon up to PR >9822
5272 60
SUSPENSION CYL
LEFT
DIAM 37
- 5 DOOR SALOON AND WITHOUT HYDRACTIVE SUSPENSION,
5272 61
RIGHT
DIAM 37
5272 62
LEFT
DIAM 37
- 5 DOOR SALOON AND MANUALLY ADJUSTED ACTIVE SUSPENSION,
5272 63
RIGHT
DIAM 37
this list is saloon from PR 9823>
5272 70
SUSPENSION CYL
LEFT
DIAM 40
5272 69
RIGHT
DIAM 40
5272 72
LEFT
DIAM 40
5272 71
RIGHT
DIAM 40
this list is estate
5272 70
01
SUSPENSION CYL
LEFT
DIAM 40
- 5 DOOR ESTATE AND WITHOUT HYDRACTIVE SUSPENSION
5272 69
01
RIGHT
DIAM 40
5272 72
01
LEFT
DIAM 40
- 5 DOOR ESTATE AND MANUALLY ADJUSTED ACTIVE SUSPENSION
5272 71
01
RIGHT
DIAM 40
- 5 DOOR ESTATE AND MANUALLY ADJUSTED ACTIVE SUSPENSION,
here is price and part No.'s for all three seals required for one rear susp unit on saloon >PR 9822, TRADE INC VAT
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
0000527218 SUSP CYL O-RING 0.92 GBP 1.06 GBP 1.06 GBP
0000527229 SLIDING SEAL 2.09 GBP 2.40 GBP 2.40 GBP
0000527231 WEATHERSTRIP 0.76 GBP 0.87 GBP 0.87 GBP,
price/part No.'s saloon PR No. 9823>
0000527228 RING-SEAL 0.68 GBP 0.78 GBP 0.78 GBP
0000527230 SLIDING SEAL 2.17 GBP 2.50 GBP 2.50 GBP
0000527232 WEATHERSTRIP 1.34 GBP 1.54 GBP 1.54 GB
for estate
sorry it wont give me the price/part No.'s for estate at the mow,
but the list above give you the part No.'s,
regards malcolm
