I said yes to help a friend change the bearings on top of his Berlingos dampers. As I am not from an english speaking country, I'm actually not sure what the word for those bearings are.
I'm used to working on Japanese cars, as I have two myself, but this french car is something else. I loosened the damper from the hub, removed the bolt that attaches the steering.. er.. arm to the hub, and removed the top bolts from the damper.
I'm used to there being enough clearance to be able to pull the damper out when you've loosened it from the hub, but all I managed to do was pull the left hand driveshaft out of the gearbox.
I pushed it in by hand, and bolted it all back together.
However, there's now a knock coming from the front left part of the car, and I'm pretty sure I've got something to do with it!
Are there any howto's on damper change on these cars, and do you have any suggestions as to what I've messed up?
I didn't remove the droplink from the damper, before you poke holes in my story.
Any help would be greatly appreciated!
