Part number needed help!
AbangCorp
Unread post by AbangCorp »
can anyone help me
i want to fit new timing belt and auxiliary belt
the problem is now i dont know what is the correct size
i think the auxiliary belt is 6pk something
i have xantia 1.9td made 95 x1
and for lower arm to be fit / press in
can anyone clarify the diameter
i want the shop to find it for me as he didnt know except if i take it with him the original one
x 94
Unread post by citronut »
has your car got air con,
also if you are after OE part No.'s can you send your chassis No.,
then i can check for you on service citroen
regards malcolm
AbangCorp
Dear Malcom
Yes, my car got air conditioner - malaysia is a hot country
My VIN for your reference VF7**************[VIN obfuscated, can be read by forum staff]
Forgot to tell you, I have access to citroen web. Registered under my father's company (its a trading company).
However I cannot find similar part for the part number given. We are more famous to v-belt manufactured by BANDO & CONTITECH (CONTINENTIAL). It start with 6PK (6 grooves) and XXXX which indicate length
Thanks in advance.
x 94
ok here is the results which came up useing you VIN No.
5750 VY
DRIVE BELT
K6-LE 1700
WITH SANDEN COMPRESSOR
5750 P2
K6 - LE 1710
WITH HARRISSOW COMPRESSOR
Part Number Description Quantity Price excl. VAT Price incl. VAT Total incl. VAT Selection
00005750VY DRIVE BELT 19.00 GBP 21.85 GBP 21.85 GBP
00005750P2 DRIVE BELT 26.87 GBP 30.90 GBP 30.90 GBP
hope this helps
regards malcolm
addo
Sara Watson's Stalker
x 95
Unread post by addo »
So depending on the compressor brand (easy to read the label) it's apparently either 6PK1700 or 6PK1710.
That sounds quite short!
x 94
there is also another set up,
but the first one i posted is what came up relatting to AbangCorp chassis/VIN No.
and stated
DIESEL XU AND AIR CONDITIONING AND 3 POINT ALTERNATOR MOUNTING UNTIL RPO No. 07358,
below is the other one which states,
DIESEL XU AND AIR CONDITIONING AND 4 POINT ALTERNATOR MOUNTING SINCE RPO No. 06809
5750 WS
DRIVE BELT
K6 - LE 1726
- DIESEL XU AND AIR CONDITIONING
WITH SANDEN COMPRESSOR,
5750 YF
K6 - LE 1736
WITH HARRISSOW COMPRESSOR,
E 117 740
RIBBELT BELT
K6 1725
- DIESEL XU AND AIR CONDITIONING AND AGE >= 5,
E 117 741
K6 1738
regards malcolm
AbangCorp
my mechanic says, 1710 or 1705
either can be used because the unit got auto tensioner
10 mm is not really an issue from his opinion
x 94
its best to get the corect belt, the diference on your car will be which air con pump you have
regards malcolm
