Hi I have a Clio rt on a P plate 1.9 d
When it rains bad nothing happens. It builds up somewhere. Then starts leaking when I'm driving. It either the sunroof seal. Or the aerial Seal. At the weekend I cleaned where the sunroof closes. Had all Leafs on in and trigs in it. Put it back on. Then sprayed the hose pipe. Nothing came out. I took the immobiliser and lights controls off. Nothing came though.
But has soon as I started driving it started leaking out
THANKS
Clio leaking though the roof
- x 5615
The sunroof doesn't seal, it lets water in but there are drain hoses that allow it to run away.
The drains get clogged and that's when you get the shower on starting off.
You may be able to blow them clear with a garage airline, otherwise you may have to trace them, usually down the 'A' and 'B' pillars, and remove and clean or renew them.
jacksun1987
- x 5615
jacksun1987
- x 5615
jacksun1987
