v6 wheels
lexi
x 133
v6 wheels
Unread post by lexi »
I aint got a spare for car. Is this wheel specific to V6 or ANY other xantias have it?. Must admit it is brill to be able to centre the wheel on when fitting.......sooo much easier. I`ve heard about the balance issues although these wheels are newish aftermarket.
The balance thing may be why they were changed in the first place.
French Mistresses gone.
Citroen C5 HDI Mk 1 hatchback
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
x 1459
Unread post by xantia_v6 »
The wheels are all interchangeable, but must match the shape of the wheel bolts. The original Mk1 V6 wheels have bolts with square shoulders, and there are matching spacers pressed into the holes on the spare wheel.
The Mk2 V6 has bolts with tapered shoulders and (I think) uses a standard Xantia spare wheel (my MK2 has a foreign spare wheel that does not really fit at all).
lexi
x 133
It may be that I can take an alloy from a standard SX diesel as long as I take the bolts that go with it. My aftermarket wheel will have bolts to suit these wheels. They are round tapered at shoulder.
Vel Satis 3.5 v6
ZX 1.9D Est.
ZX 1.9DHatch
Xantia 1.9td est.
Xantia 2.0 hdi Est.
Xantia V6 MK1
Xantia V6 MK 2
Stunned Monkey
Unread post by Stunned Monkey »
If you mean the 7 spoke alloys, they're the same on an Exclusive - not that that is much help as they're not exactly common either. They're about £100 from Citroen however - I've had three over the years - lots of country lane driving!!!
Martin
Old Faithful: Silver V-reg Xantia HDi Exclusive, died due to tin worm @ 259k miles
New Faithful: Silver W-reg Xantia HDi Exclusive, 169k miles and counting...
Previous: Various BX's, XM V6 24,
Venturi Atlantique 300, Alpine A610
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You need a good 3/4-7/8" of thread coming out the wheel's mating face when the correct stud is used.
V6's had 6½J rims from factory; Activas and some diesels also had this width. Many Xantias were 6J.
Stunned Monkey
Yeah, Exclusives and V6's have the same running gear as the Activa, just different spokes.
Martin
