C5 2.0 Hdi Immobilisor Active.
While driving (my son's) C5 yesterday, everything suddenly went from normal to engine cutting out and display showing "immobilisor active". I removed the two fuel pipes (one is s return pipe) at the fuel filter, and cranked the engine - no fuel coming. Checked the pump (under the seat) and some fuel was present outside the pump & on the pump cover. Called the breakdoen service and the guy found one of the pipes leading from the fuel pump loose. Tightened that, & can hear the pump (buzzing)pressurising, when the ignition is turned on, but it will not start. Took the car to a Citroen dealer, but at 4,30 on a Friday evening nobody was prepared to investigate the problem. Any thoughts on this problem appreciated.
