Xantia HDi timing belt snapped WHAT HEADGASKET????
scoles
Unread post by scoles »
hi new here,
the above happened to my xantia its a X reg 110bhp HDi i have been told that the pistons are shot and every rocker is broken.
so am looking for an engine only thing is i dont understand the engine codes...i dont know which mines is and what HDi engines will fit.
my engine number is DYCS4008105 can anyone tell me the actuall engine code from that...i notice there are RHYengines and such.
any help is much appreciated.
Stuart
Xsarahdi
Unread post by Xsarahdi »
I am fairly sure that the 110 hdi has the code RHZ (DW10ATED).
2005 C3 1.6 HDi 110 VTR
2003 Xsara 2.0 HDi 110 SX
1999 306 1.9 TD Meridian
1996 ZX 1.9 D Elation
scoles
Hmmm that doesnt help me all that much, as thats the number from the engine. can anyone tell me if there are any other markings on the block/ head that would indicate what the engine is.... i know for sure its supposed to be the 110bhp model as thats what comes up with insurance on the number plate.
Cheers
Stuart
x 8264
Offtiimes it is only the rockers that break so if you feel brave, replace those and see if the engine is OK. The valves are at 90 degrees to the pistons and apart from leaving indentations in them, damage (apart from the rockers) is often surprisingly minor.
How were the pistons deemed to be "shot"
DW10ATED is the correct designation for the engine. Donors include the Xsara, Pug 306 and 406 and a number of PSA White Vans. Any breaker worth his salt will know the correct engine.
Paul (CitroenXM) may be able to tell you that an HDi 90 engine can be used with some changes.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Heads and blocks are basically the same, although there are a few small differences, BUT a HDi 90 engine WILL do the job just the same, and I HAVE prooved this to myself, as the HDi 90 that I converted to 110bhp has faultlessy run for 15000 miles ALREADY... From a 90 to 110, you'd ONLY need to swap Turbo and inlet manifold from the 110 unit, AND the flywheel and thats the biggest changes... ALL the fuel system DOES NOT need changing!
Here is my original post about the dreaded swap..
As for your damage,
The Pistons WONT be shot, they DO NOT damaged internally like the old XUD engines doo..
you SHOULD ONLY need to change the rocker fingers, as these are designed to break and take the impact so theres no need to remove the head!!
Get a set of Fingers in and she should be right as rain!!!
Paul
PS: Where are you located?? Ive got a HDi 110 Block and head here, head HAS been machined, it just needs a Head Gasket..turbo, inlet manifold and she should be right as rain!
A very sad...
1994 XM 2.1 d auto
scoles
citroenxm wrote:Heads and blocks are basically the same, although there are a few small differences, BUT a HDi 90 engine WILL do the job just the same, and I HAVE prooved this to myself, as the HDi 90 that I converted to 110bhp has faultlessy run for 15000 miles ALREADY... From a 90 to 110, you'd ONLY need to swap Turbo and inlet manifold from the 110 unit, AND the flywheel and thats the biggest changes... ALL the fuel system DOES NOT need changing!
As for your damage,
Paul
Thanks for that, i am based in fife, Scotland. unfortunately the mechanic already ripped the engine to pieces and left me with a boot full of parts..
Personally i seen the pistons today and there isn't even a mark on them at all...the carbon hasnt been disturbed.
My main issue is that now i have a bot full of pieces and i never took it to bits.
I havent had a lot of experience with diesel engines...but have rebuilt a few petrol engines.
I would be doing the work myself anyway.
With regards to the head that you have, could you PM me a price as i might just have it and rebuild the current engine as it was running sweet as a nut before hand... it was the auxiliary belt that snapped and became tangled in the timing belt that caused the problem.
There is a HDi engine from a 2005 berlingo i think it is on ebay, i was unsure if this would bolt in as it "looks" the same.
stuart
citroenxm
Fallen Hero
x 70
Id consider an Exchange with your head...
PM Sent
Paul
A very sad...
1994 XM 2.1 d auto
x 1055
Unread post by wheeler »
I've seen quite a few 2.0 HDi's with broken timing belts & not one has even had a bent valve nevermind a damaged piston, the rockers always take the impact, replace the broken rockers but make sure you get all the broken bits out of the head with a magnet.
HDI
x 7
Unread post by HDI »
No bent valves with a broken timing belt is amazing !! Are the rockers designed to be a mechanical fuse then ? If thats an intentional design feature I'm impressed !
BTW , how did a broken ancillary belt get tangled in the timing belt ? It's fully enclosed in covers.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
citroenxm
Fallen Hero
x 70
HDI, I thought you'd know that!
The HDi unit was intentinally designed like that after XUD experiance's of broken cam belts taken Cam SHAFTs and Cap Bearings too, they didn't want that much of a disaster again, so in a word, Yes you could see them as a fuse...
Paul
A very sad...
1994 XM 2.1 d auto
HDI
x 7
Neat !! Pity engines don't have bevel gear & shaft driven cams any more , just think , no muckin cam belts to change !!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Toby_HDi
x 3
Unread post by Toby_HDi »
Yep, my old HDi slipped its belt. Ended up with one broken rocker. Replaced it and put it all back together and all was fine.
I would offer to help, but alas, although I do visit Fife occasionally, it is a bit of a trek
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
scoles
HDI wrote:BTW , how did a broken ancillary belt get tangled in the timing belt ? It's fully enclosed in covers.
This was the conclusion drawn from the mechanic, he found the belt snapped and tangled around the timing belt.
I did wonder when i glanced at the pistons and the head and seen no marks on the crown of the pistons and all the valves seating properly, although i havent tried moving the valves to see if they are free but definately doesnt resemble the sight of a timing belt failure that i am used to seeing on petrol engines.
BTW cant believe the quick information and help given to a newbie, by far the most helpful and friendly forum i have joined. usually people with higher post counts on other forums tend not to communicate with the newbies like me.
Cheers
Stuart
HDI
x 7
I'm pretty new myself and agree FCF is one of the most helpful & friendly forums I've ever used. Really is refreshing to have non of that belligerent nonsense that often occurs on other forums.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
uncle buck
x 10
Unread post by uncle buck »
from whats been said it sounds like your mechanic is a bit out of date....in as much that he's thinking along the same lines as I would have been before reading this thread.....that a snapped cam belt only takes out the rockers & not the head like it used to on the 1.9 TD engines....I never knew that.
Vauxhall engines used to be like that ....the rockers were the weak part so if the worst happened (snapped cam belt) they would snap & in doing so save the head...a good design it has to be said.
Hope you get a result...good luck.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
