Xantia track control arm bushes.
Brigsygtt
Unread post by Brigsygtt »
Need to do my tca bushes on my xantia asap as there knocking like a gooden.
Im going to order the bushes from gsf as there a lot cheaper than my local motorfactors. Looking at the website there are two different tca mushroom bushes?
N42227A FR TR CON ARM BUSH-FR XANTIA(MUSHROOM SHAPE)
N42227 FR CONT ARM FR BUSH XANTIA FRONT BUSH (MUSHROOM SHAPE)
Which one do i need? my xanitia is a 97 1.9td lx..
Cheers in advance :)
97 Xantia 1.9 td lx with a/c (Daily, 172K, FOR SALE)
98 Xantia Hdi Lx with a/c (105k)
97 Renault Extra (c1j turbo 230+hp, 12.88@106)
91 Renault 5 Gt turbo (68k minter)
addo
Sara Watson's Stalker
x 95
Unread post by addo »
Possibly, one is just a different brand to the other? I fitted Sasic ones last week.
Don't forget to re-torque with the motor running and the car at normal ride height...
x 94
Unread post by citronut »
and weight on its wheels,
are you sure its the arm bush's as knocknig is usualy the anti roll bar drop links
regards malcolm
Brigsygtt
Aye will tighten them up when theres weight on the wheels.
Could poss be two different make of bushes?
100% sure its the bushes. The droplinks were replaced recently, its a heavy knock not the tap like they make.
The bushes are heavily cracked & the track control arm will move easily when car is jacked up, the p-bush is like a floppy thing. Havent done bad for 161k though.
x 94
ok you will have enormous fun fitting them especialy the P bush, it can sometimes work out more cost efective to fit a new artm with the bush's already fitted,
cost efective only as fare as time is cocerned
regards malcolm
Brigsygtt
Got plenty of time so will give the bushes a go. Also just got meself a nice 20 ton press which should be up to the job. I done the rear bushes on my old ax derv with a hammer & vice, similar kind of setup?
I was going to buy a full arm, but the price difference is massive, ill be grudged paying the extra. I prefer genuine tca's, pattern parts always seem to be poor imo.
Cant be any harder than the gt turbo bushes, i had to grind/chop the old track control arm off as the bolts rust solid in the metal inserts!
x 94
ok
you will need to cut the inner sleave of the P bush off as it is an interferance fit, and make sur you get the new one back on in its corect orientation/plane
regards malcolm
addo
x 95
I had a curly one with my changeover. The guys somehow managed to tweak the height control link - you could see the chafe marks - when pushing the ARB away to free everything.
It's best if you don't have this misadventure, as resetting the ride height took so many iterative tries - even when getting close, it was forever 3/16" the wrong way!
Brigsygtt
Bushes done, no big deal really took about 4 hrs. The p-bush/mushroom bush on the passenger side had fell to bits, arm just fell down when the balljoint was cracked off.
Drives mint now, floates along instead of crash-bang. I have noticed the front end sits higher now though, possibly have disturbed the h/c mechanism when the arb was loose?
Has anybody got a rough floor-cill measurement so i can check?
addo
x 95
Warm engine, correct LHM level, car lowered to bump stops then raised to normal and allowed to idle a few minutes. Tyres 185/65/15 at 38-ish PSI.
Did my best to photograph it square on. Ground is pretty level, too.
Brigsygtt
Cheers for the pic addo, my tyre to arch gap doesnt look too different to yours in the pic. Mine was a bit lower on the passenger side before i replaced the p-bush could have been down to the lack of tension on the bush before?
Ill get the tape measure on it tomorrow 8)
