windows steaming up
allanmc
windows steaming up
Unread post by allanmc »
Came across a thread about windows steaming up on Xantias with AC and it pointed to a clogged cabin filter is this the Pollen Filter? Allan
HDI
x 7
Unread post by HDI »
Indeed it is. Cabin ventilation is dependant on the pollen filter being unobstructed. Find it in the passenger footwell under the trim below the glove box. It's under a rectangular plastic cover that slides off , then the filter pulls out.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Clogzz
x 40
Unread post by Clogzz »
Image Image
allanmc
windows steaming up
Thanks for getting back so quickly, 2 seconds and it was out, thats one more reason for ignoring the Haynes Manual it said I had to remove 3 screws to get to the filter.Thanks again I just to decide whether to replace or wash it.
Allan
HDI
x 7
Replace it. Get one from your local motor factor , will be cheaper than a main stealer. The one I got was Fram.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
If your STILL getting steamed up on warm setting then its BAD NEWS only :(
Lets hope this has cured your problem
Paul
A very sad...
1994 XM 2.1 d auto
x 94
Unread post by citronut »
the other reason for windows steaming is water getting into the car,
either leaking in or heater matrix,
as Paul says hope the above fix's it
regards malcolm
Mandrake
x 695
Unread post by Mandrake »
If theres a very tiny leak in the heater matrix it seems to coat the inside of the windscreen with a grimy but invisible film that fogs a lot more easily than clean glass.
When I got my Xantia the (apparenty clean) windscreen fogged far too easily and normal wiping with a cloth didn't help for long. A few months later (yes I'm a dumbass for not trying it sooner) I gave the windscreen a thorough clean with meths and a soft rag and presto, it stopped fogging up all the time.
I'm sure there was a tiny leak from the heater matrix but just by giving the glass a clean with meths every few months it stopped fogging up for the 4 years I had the car...
So first port of call is to try cleaning it with something that will remove that film - standard window cleaner spray may work as well, but I had such good results with meths that I never tried anything else...
Regards,
Simon
Simon
1997 Xantia S1 2.0i Auto VSX
1978 CX 2400
1977 G Special 1129cc LHD
allanmc
windows steaming up
Thanks I,ll try that but i am still hoping that a new filter will cure it which I have just ordered on e-bay.
Allan
Kowalski
Unread post by Kowalski »
You should also check that the drains in the scuttle panel (outside, in front of the windscreen) are not blocked with leaves. When the drains get blocked, rain water ends up in the ventilation system and the footwells and can make your car steam up.
Old-Guy
x 24
Unread post by Old-Guy »
If it's an estate, check (under) the carpets in the load space and rear footwell. The tailgate is prone to a variety of leaks - all straight forward and inexpensive to fix. Have a look at 'Things you won't find in the BoL' on my webpage.
It's also a good idea to get into the habit of always parking an estate nose-up if on a slope.
So if your drive slopes up off a classified road, you'd better move house! :lol:
