I've got the offer of a 51 reg TDi manual air con version with 80k at the right money which I'm considering buying for my own use as a dual purpose private/work vehicle. Wants a bit of bodywork which I can do.
Anything to check/look out for on these?
Very similar to Citroen Synergie/Fiat Ulysse.
Bumperman
Peugeot 806-are they any good?
bumperman
93 Peugeot 405 STDT ser 2 Estate manual Alhambra Red
89 Peugeot 505 GTi Estate manual Winchester Grey
87 Peugeot 505 GTi Estate manual Winchester Grey
96 Xantia td SX Estate RP6910 manual Quartz(silver)
Gammy leg
Bumperman,
I've got the Citroen Synergie Td 'W' reg which I've had for 4 years. Mechanicals are almost bulletproof and require minimal attention, electrics do suffer from usual gremlins though and I've had problems with C/Locking and indicators but nothing more than irritating stuff - nothing terminal.
Worth making sure that the transmission doesn't grate when changing gear as the syncro's are not overly strong although I drove mine up and down the pyrenees with no 2nd gear a couple of years ago. Still not fixed either!!
It drives more like a van than a car but as a practical work/private use vehicle it is superb. I honestly would not be without it.
Surely being a 51 plate, yours will be an Hdi which I believe is not quite as robust as the Td.
Please feel free to ask questions about specific parts which could be common between the 2 models though.
Gammy
Gammy
LLOYD
