405 alarm
Toby_HDi
x 3
405 alarm
Unread post by Toby_HDi »
Some weird goings on with my sisters 405.
She went to start it the other day, had a flat battery. So I took it off and charged it. After a charge it still only showed 12.6v so can only assume its had it, it did start the car however.
The problem is that removing the battery seems to have reset the alarm. Every time the door is opened the headlights flash for 30 secs or so. No siren though
I'm led to believe that locking and unlocking using the plip will work but her plip is broken. The alarm key under the bonnet seems to do nothing.
Any ideas? Can a key be reprogrammed using a Lexia or DIAG2000 if one was obtained and its guts put into the plip my sister has now (so that she had the right blade)
Toby
Previous:
2004 Peugeot 407 HDi 138 SE Luxury Pack
2001 S2 Xantia HDi 110 SX
2001 Peugeot 406 V6 Coupé
1998 S2 Xantia Activa
2000 S2 Xantia HDi 110 SX
1999 Peugeot 406 2.0 16v Estate
Toby_HDi
x 3
Anyone?
Toby
Previous:
x 8450
Sorry Toby,
Wish I'd seen this earlier :oops:
If the plip is not working, try holding down the ultrasonic defeat button on the steering wheel cowl whilst turning on the ignition. Hopefully it's like the Xantia arrangement and that'll reset it.
Toby_HDi
x 3
No worrys Jim.
Just tried your suggestion and it worked a treat! Thanks for that.
All is now reset
Toby
Previous:
x 8450
Brilliant Toby :D
