climit control problem
mark21td
Unread post by mark21td »
I have a problem with my CC,
If I have the fan in auto and the temp setting in HOT the fan only blows slowly but I do get heat from it,
if I lower the temp a bit it blows cold air and the fan speeds up
the blower works fine in manual but still not that hot.
is this down to the litle fan in the dash (the one above the radio) as I beleave this is the temp sensor.
Sorry should of said it's a 97 Xantia vsx 1.9td.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
jgra1
(Donor 2021)
x 36
Unread post by jgra1 »
my post not relevant :shock: :D
mark21td
Ah, I see what you mean, the only problem is if I use it in auto as you should it just blows cold !
jgra1
(Donor 2021)
x 36
sorry Mark I wrote all that and re read yours twice and realised I had missed some important bits (late night)
I think if you are only getting any heat when fan speed is low, that maybe you just dont have enough coolant in the matrix, or there is something wrong with the air diverting flap that sends air to or away from the matrix..
the internal sensor shouldnt really affect the temp when you are on manual override.. that should give hot at any fan speed?
mark21td
I know what you mean bout a late night, I've been on nights :lol:
I do get heat when the fan is in manual and heat setting is high just not in auto.
jgra1
(Donor 2021)
x 36
ahh :D in that case I think you may be right with your original prognosis... the sensor is easy to remove.. a small unit with a fan on.. I think they get pretty dusty.. may be worth removing it and having a look, make sure the small fan turns when the ignition is on and Auto selected?
I may test mine this week with a thermometer in the car..always wondered how accurate CC is :D
HDI
x 7
Unread post by HDI »
Ah , so thats whats behind those little slots !! If my pollen filters anything to go by I bet mine is caked in dust !! The CC in mine works but has a tendency to leave the upper air too cold after heating the cabin upto temperature in cold weather.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
jgra1
(Donor 2021)
x 36
I know in the 406, I am not happy in the car unless the climate says 23 :shock: which seems a bit high really..
will report back with thermometer readings.. I ahve a double sensor, one can go on vents and the other somewhere else..
HDI
x 7
Cool !! 8)
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Clogzz
x 40
Unread post by Clogzz »
It’s deliberate for the fan to go slowly at maximum temperature setting.
The air is hotter when it passes through the heater core slowly.
Since it’s hot at maximum, it means that the motorised heater flap works.
The heat comes out mostly from the bottom, because it’s meant to rise.
The face and windscreen airflow is controlled by two cables on the top left slider.
2002 C5 2.0i AL4 239,000 km 76372389
x 8093
Mark, if you do find the little fan in the cabin temperature sensor is good, clean and spinning nicely then your next best course of action is a good old Lexia session on it as the Lexia can exercise the temperature flap to ensure it's working well and check the operation of the three other temperature sensors. there's one in the air intake above the recirculation flap (impossible to get at), one for the footwell temperature and one in the middle of the heater box. If any are playing up they will confuse the climate control ECU.
The cabin air temperature sensor is a mite bit hard to get to if you need to replace it. Steering wheel off, cowls off, switch panel out and then wireless, ashtray, fascia vents and finally you can get to it :twisted: That's for a MK1. for a MK2 it's marginally easier as there is no need to remove the steering wheel...
HDI
x 7
Witches sister !! Is Anything on these things easy to do ??!! :x
Wonder when I'll get a chance to try a fabled Lexia ??!!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1432
You can, just, do it without taking the steering wheel off, but it's not necessarily easy.... Some of them seem to just pop out with a gentle wiggle, but the ones I have played with have been tight. Remove the radio and surround then you can reach in and try and push the sensor out - the clips are top and bottom, so it may just wiggle out. If not try taking the clock out so you can get to the side of the sensor.
On a MK2 you will need to remove the switch panel, as there is no separate grille for the sensor like there is on a MK1.
You may well find though, that the motor is broken - they use a small brushless DC jobbie, and the electronics are prone to going belly up, so the fan only kicks, not rotates.
MikeT
x 232
Unread post by MikeT »
RichardW wrote: Remove the radio and surround then you can reach in and try and push the sensor out - the clips are top and bottom, so it may just wiggle out.
That's the method I use and it works every time.
Jim, I think I've got a working spare for you - I just have to be sure my apprentice didn't damage it on removal :oops:
x 8093
MikeT wrote: Jim, I think I've got a working spare for you - I just have to be sure my apprentice didn't damage it on removal :oops:
Thanks Mike :D :D Will swap it for a Lucas DPC :wink:
