bad starting again sorry
andrew b
after trying an earlier suggestion of undoing an injector pipe i have discovered there is no fuel until the engine is turned over 3 or 4 times.i cant find an air leak anywhere so could it be the pump itself?
JohnD
- x 72
andrew b
Dave Burns
- x 3
andrew b
Dave Burns
- x 3
Depending on which union was opened and where the engine had stopped, there can be 4 compression strokes before any fuel will be pumped to that particular injector.
Would I be correct in thinking that you may be confusing the fluctuating sound of the starter at each compression stroke, for engine revolutions, as 4 compression strokes is 2 engine revolutions, so 4 revolutions would be 8 compo strokes.
Sounds a bit daft to be asking such questions but I obviousely don't know your level of mechanical prowess, so it has to be asked because what you are seeing could be normal.
Dave
Dave
andrew b
Dave Burns
- x 3
If the fuel level in the pump had fallen low enough to cause this, you would get between eight and twelve squeezes of the primer bulb before it firmed up, but you say you only get a couple, this means there is ample fuel in the pump because the primer bulb will only firm up when diesel reaches the outlet restrictor high up in the injection pump.
Could be a sticking solenoid, easey to find out if it is by removing the spring and plunger from it, providing its not a keypad or transponder key model.
The actual pumping action of the VE pump is very simple and extremely robust and reliable, the complicated part is the govenor and the levers and springs, I would think anything wrong in this department would manifest itself in other, worse ways that this.
Dave
Dave
mipster
andrew b
