Tailgate lock problem
VertVega
x 13
Unread post by VertVega »
It is an unpleasant surprise to notice that tailgate lock doesn't work Image
All other doors are locking and unlocking. There is a clear motor sound from the tailgate each time I click buttons on the key, i.e. not a broken wire case.
Thinking positive, it's LOCKED :)
I'll try to check tomorrow day time. Has anyone experienced the same? Any ideas?
addo
Sara Watson's Stalker
x 95
Unread post by addo »
You know it may be carefully released from inside, either by prising off the lower latch plastic and unscrewing the striker (12mm deep offset wrench), or tripping the nearly hidden release lever adjacent?
There seems to be clear vinyl around some parts of the latch - possibly a piece has peeled away to jam the lock mechanism...
MikeT
x 232
Unread post by MikeT »
You are aware (therefore not fouling foul of) the special feature the hatch locks carry, I trust?
VertVega
x 13
Thanks addo, tomorrow I was planning to get my camera and "dive" into the problem source by lowering rear seats :)
MikeT, estate locks are different than sedan ones, no key hole. There's a handle which doesn't function at the moment. Tailgate is in the locked position.
x 8391
The estate locking mechanism is a bit strange. Your problem will be caused by a seizure of the mechanism the locking motor pulls/pushes and is quite common as it gets wet regularly. Even when totally seized, you'll still hear the motor operate as it has a clutch built into it. It is in fact identical to the motors used in the Peugeot 205 and is not a deadlock by any means.
How to get into the tailgate to unlock it though is tricky. You may just be able to fiddle it by removing the light clusters which is possible after removing the bulb access panels. You should be able to grab the link rod from the motor to the mechanism after cutting a small access hole in the polythene membrane. You'll need to then remove the tailgate trim and reseal the membrane after giving all the linkages a good lubrication.
You may find the central locking motor has failed in one direction (i.e it will push to lock but not pull to unlock). test it very thoroughly before replacing the membrane.
To help you visualise where the motor is, Look at the tailgate from outside, imagine it is transparent and look to your right. The motor will be around half way up above the light cluster.
VertVega
x 13
Thanks Jim, I bet this will be a very interesting job. I'm already very anxious for tomorrow and I will take pictures as usual :)
VertVega
x 13
Problem solved, case closed, happy Xantia owner :D
Here's a brief update, I hope it'll be helpful for forum members (and guests).
As CitroJim said the locking mechanism is a bit strange. Actually the lock is enabling/disabling the handle!
When it's locked the handle is disabled. It can be released from inside, thanks addo! Trim removal is easy and
I have done it several times before. Plastic membrane doesn't have to be removed completely but just the half way
from the upper part. Important: if membrane adhesive is in bad condition,especially from lower part then it should be
removed completely and old sealant must be cleaned. I have used 3M auto glass ribbon sealer for new adhesive.
The tailgate lock motor sometimes failed to lock or unlock. Sometimes push pull mechanism (see markings in pic) didn't work.
I have bought a used one from a scrapcar and installed. It works fine (now 1 week).
Once again thanks for your help!
If you are also interested in How_things_work :) the lock motor mechanism is seen below.
_____________________________________________________________________
I found this thread where Xsara Estate tailgate lock opening trick is explained
(It was same for Xantia) --> http://www.frenchcarforum.co.uk/forum/v ... t=tailgate
Also read in another thread where C5 tailgate lock opening from inside in the same way.
falling-out-with-my-car
x 25
Re: Tailgate lock problem
Unread post by falling-out-with-my-car »
if you know you want to open the boot before you get out of the car, open drivers door and reach across and push down the
front passengers side door lock which will lock/unlock the central locking mechanism on all doors, the system senses that one door is still open ie your drivers door and unlocks the mechanism, repeat pressing the button down on the passenger door until you hear the boot unlock itself then spray liberally with lithium grease around the boot lock and it should be fine, the solenoids are a bit weak so keeping the cars battery charged up especially ion the winter can help with this problem, I find it works most of the time.
