A mysterious squeak.
Chlorate
Unread post by Chlorate »
There's been a horrible squeaky noise coming from the general area of the alternator belt on my ZX since I put it back together as well as the occasional squeal of the belt slipping. At first I figured it was the belt tensioner bearings knackered.
So I replaced the tensioner with a shiny new one, and yes the bearings were indeed busted. But that didn't stop the squeaky noise.
I'm wondering whether it's a symptom of power steering pump failure or alternator bearings or if it's just that the belt is a bit too loose.
The steering has felt a little heavier lately, but it's hard to tell.
Anyone got any ideas?
Thanks guys.
Citroen Xantia Exclusive HDi
previously:
Citroen ZX Volcane - RIP
Peugeot 106 XN... stolen and destroyed by Kent Police :evil:
HDI
x 7
Unread post by HDI »
Is the belt running out of alignment ? I had this same problem with my HDI and after replacing the belt , tensioner and scratching half my hair out I eventually discovered that some muppet in the past had refitted the hydraulic pump out of alignment ! Corrected that and there was silence :)
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Chlorate
That may explain it if my crankshaft pulley is on a little wonky...
previously:
x 94
Unread post by citronut »
these o rib al ribed belts do need to be very tight compaired to the good old V belts, so it might be woth adjusting it up just a bit more before you go looking for other thuings at fault
regards malcolm
