Hi, my 2002 2l diesel estate c5 has not been able to start 3 times. Mechanics cant find fault because by time I tow to garage its started to work again. No fault codes, good continuity of cable from relay to elec pump, fuel pump relay is clicking, fuse is good.
Any ideas?
C5 intermittent starting fault
- x 1052
dodsy
- x 1052
check the 16 pin grey connector on the under bonnet fusebox, this is where the fuel pump feed comes out, the pins can over heat & cause connection problems. have a look at the pins on the fusebox carefully & check to see if any of them have a blue coloured coating (cant remember the pin no off hand), clean the pin & re fit & see if it works then.
