Berlingo
JohnP.
Berlingo
Unread post by JohnP. »
Hi there,can someone tell me how to change the clock on my Berlingo van?[:I]
I've pushed,pulled, and twiddled both of the little knobs on there with no effect on the clock at all.[:(]
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
I've no idea - but there might be a chance that its the same as the Saxo. If its digital turn the button to the left for minutes, to the right for hours. If its analogue, press the button for two seconds and the minutes advance slowly then rapidly. If all this is of no help, then - sorry!
JohnP.
Thanks John,it is digital, I'll give that a go for starters.
x 1050
Unread post by wheeler »
if its a later model berlingo with digital clock,have the ignition on but engine NOT running,press & hold the right hand button till the hours start flashing,then press the right button till you get the hour you want,leave for a few seconds then the minutes will start flashing,press the right button againg till you get the minutes you want,leave for another few seconds it will stop flashing.clock set!
JohnP.
Thanks wheeler,I'll try that next,so far I have at least discovered the tripmeter.[:)]
I don't think I've ever had a handbook supplied with a second hand van,it would make life a lot simpler.
JohnP.
Sorted now,thanks guys,wheelers method was the one,JohnD discovered the tripmeter for me though.
