I'm getting a recurring code (after clearing correctly) for this "Engine speed sensor", and the car is stumbling sometimes as though it's on the verge of cutting out.
At 150K kilometres, with ample rough roads and a hard life generally, is the part likely to have failed? As in, does this part commonly fail, or is the stumble and code due to some interlinking detail - like the seatbelt pretensioner plugs causing airbag warning lights to trip?
RRP for the sensor here, is $185 - that's £104. I haven't investigated interchanges other than across the PSA marques.
Thanks, Adam.
Xantia (etc) Petrol Engine - Crank Angle Sensor
addo
- Sara Watson's Stalker
- x 95
MikeT
- x 232
Hi Adam, I don't know about the PSA motors as I can't recall ever seeing a reported failed engine speed sensor but some modern Fords for instance, do seem to have design problems where the engine speed sensor doesn't fail but moves beyond range or the gap is interfered with somehow such as with accumulation of dirt etc and causes the running symptoms you've given. Perhaps it's worth checking it hasn't dislodged or is in need of clean? Do you have test equipment to view the signal or lack of?
addo
- x 95
addo
- x 95
