Useful Utilities
ellevie
Useful Utilities
Unread post by ellevie »
From time to time people mention computer based utilities which I find useful as I'm sure do many of you.
Here is a very useful utility called JDiskReport which I find extremely useful. If you're trying to find out exactly where all your valuable disk space has disappeared this is just what you need. When installed, if you right click on any directory it will give you the option of displaying the size of the various subdirectories underneath it in the form of a pie-chart. Clicking on any of the segments representing a directory in the chart produces a new chart showing the size distribution of that particular directory. I used to spend ages doing this kind of thing manually.
The program is free and has no advertising or other nasties included as far as I'm aware. It can be downloaded here,
http://www.jgoodies.com/freeware/jdiskreport/index.html
David
BX19TRS 120K E Reg 1992-2013
BX19TRS auto abs 96k F Reg
BX19TXD 150k K Reg
x 5675
Useful looking tool there ellevie.
A very similar one is part of the system tools in Linux.
Not often needed but very handy when you do.
ellevie
What's the one on Linux called ?
I intend to have a go at Ubuntu now that I have a more powerful machine hooked up to my aging laptop.
JDisReport is also available in Java and Mac Os X.
David
BX19TXD 150k K Reg
x 5675
Something very pedestrian IIRC - not on the Linux machine right now but will boot it in a while and check.
New version of Ubuntu out next week :)
x 5675
Unable to find it, not on the current system by the looks of it, must have discarded it with the last update. Rarely looked at it anyway.
Will continue to try and find it but several hours searching haven't thrown anything up.
ellevie
Thanks for looking anyway. I seem to spend half my life searching for thing I have lost myself !
David
BX19TXD 150k K Reg
x 5675
Here it is :)
Scroll down to "Disc Usage Analyser".
Typical that Google found it where I couldn't. Not on the Ubuntu machine again but will have a proper look and post a screenshot if I find it, the one in the article doesn't bear more than a superficial resemblance to mine.
ellevie
Thanks for that. I'll look forward to doing a "compare and contrast" when I get Ubuntu going.
David
BX19TXD 150k K Reg
ellevie
PhotoFiltre
Quite some time ago Jim asked if there was a suitable freeware tool to crop and resize JPG images and after some discussion the general consensus favoured IrFanView.
Here is an alternative French based offering called PhotoFiltre which has a similar small size and efficiency but is primarily intended for photographic post processing.
You are not expected to make a donation to the author as there is a professional version available.
It is available here http://photofiltre.free.fr/
David
BX19TXD 150k K Reg
