ZX keypad code
ken newbold
x 4
ZX keypad code
Unread post by ken newbold »
Can anyone please tell me, is it possible to change the code on one of these keypad things?
Many thanks Ken
1998 1.9td Peugeot 806 (Red shed 2)
2004 Citroen C3 1.4HDi
2003 2.2 Pug 807, Gone and never again!
MikeT
x 232
Unread post by MikeT »
Yes, if it's the same as the Xantia. Instructions can be found in the handbook. If you don't have one, I'll dig mine out and post here or someone else will beat me to it.
It's also possible to add a "service" code for mechanics etc to use.
admiral51
x 389
Unread post by admiral51 »
Hi Ken
Assuming its the same as the Xantia keypad then this is the way to change the code
1.switch ignition on and wait 30 secs
2.enter current code and press C
3.enter your NEW 4 digit code and press C
Four flashes of the green lamp coupled with four beeps means new code stored
4.switch ignition off
5.open close and lock the drivers door
6.wait 30 secs
7.unlock and open drivers door
8.switch on ignition and enter new code
9.if things have gone well you are able to start the car :lol: :lol:
As Mike says you can enter a service code if you need/want to take your car to a garage so that they dont know your own code to do this the procedure is as follows
a.turn ignition on and enter your normal code
b.within 10 seconds press the S button
c.enter your choice of a 4 digit service code and press the S button
the green light should flash 6 times accompanied by 6 beeps
The service code will be accepted until you enter your normal code.To reactivate a service code you need to follow the steps a/b/c.
Hope this helps :lol: :D
Colin
uncle buck
x 10
Unread post by uncle buck »
You can disable them as well can't you?...
I'm sure I've read on here of how to do it.....saves you having to put the code in all of the time.
Cheers.
2006 C4 1.6 HDi 16V (92) non FAP
2001 Xsara II 1.4 LX
2001 Renault Laguna II 1.9dCi Sport Tourer
admiral51
x 389
uncle buck wrote:You can disable them as well can't you?...
Cheers.
Yes you can and its very very simple to do but this is a public forum etc etc etc etc.......... :lol: :lol: :lol:
Colin
ken newbold
x 4
Many thanks for that, I'll try it tomorrow, at least I'll have a number I can remember.
It's the first car I've had with one of these things and I can see it becoming a bit of a pain. I may be back for the other info later :)
x 1044
Unread post by wheeler »
Cheers.
Colin
You still need the correct code to do it so it doesent matter if it's on a public forum.
Pleiades
Unread post by Pleiades »
I find that the disable route is the best, as I find it a real pain putting a code in every time you need to start the thing.
Not realy a problem on a public forum as it's not as if you are giving any secret pin numbers out, so I will stick my head over the parapits and say...
Remove the keypad but leave it connected.
Turn the ignition on.
Put your code in.
Start the car.
Dis-connect the wiring plug from the back of the key pad.
Put the pad back in it's hole.
Jobs a good un.
Dont forget to write the last used code down somewhere (logbook) cos if you ever decide to re-fit, you will need the last code used.
Regards
Martin.
xmexclusive
Unread post by xmexclusive »
Hi Martin
It helps for all us parts scavangers if the "old" code is written on the ECU as well as a recovered ECU without a code is a pain to sort out.
When a new owner gets a car with the keypad in this disconnected state then experimenting with reconnecting is very risky unless you are absolutely certain about the start code. Plugging in with the ignition on resets the ECU to look for the old code on next restart. I only know about XM's but there were 4 different versions of the keypad/ECU combination between 1993 and 1997. Each new version getting extra security features.
John
Xmexclusive
uncle buck
x 10
Pleiades wrote:I find that the disable route is the best, as I find it a real pain putting a code in every time you need to start the thing.
Put your code in.
Start the car.
Jobs a good un.
Regards
Martin.
I knew someone would know...And spill the beans ! :lol: .....Thanks.
Cheers.
