306 turbo d m plate window problem
scottishpaul
hi my 306 eletric window on passenger side will go down but not getting power to go back up will this be a relay fault any one got any ideas
pug 306 -turbo d 1993 -2001 xantia hdi 90 bhp -2000 partner van 2.0 hdi 90bhp
Onlinemyglaren
- x 5622
- x 94
more likely to be a broken wire or three in the door shut, if this is the case make sure any fix you do patching wire in you attatch enough wire so all joints are inside the door pillar and not in the door shut, or they wont last long,
peugeot do a repair section for about 75 quid, this is the large round door shut plug and a bunch of wire's/tail's
regards malcolm
regards malcolm
