Converting C5 auto to manual
C5
looking into the possibility of changing a c5 wagon 2003 auto to a be4 manual is it possible considering all the computers etc gearbox and linkages / clutch pedal no probs but do i have to change the computers or can they be reconfigured with lexia to except the manual
Citroenmad
- x 110
It would be far easier to sell the car and buy a manual one. Not sure exactly whats involved but its not going to be easy!
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
03 Seat Arosa 1.0S
cachaciero
- x 9
Re: Converting C5 auto to manual
C5 wrote:looking into the possibility of changing a c5 wagon 2003 auto to a be4 manual is it possible considering all the computers etc gearbox and linkages / clutch pedal no probs but do i have to change the computers or can they be reconfigured with lexia to except the manual
Hi
If you can sort the mechanical issue's then I don't believe that the computer issues are insumountable. The autobox ECU's interaction with the rest of the car is as far as I can see minimal (but I could be wrong !) .
Might be worth disconnecting the Auto Box ECU on the car you have and see what "barfs" may give you some ideas of the things that you will have to find solutions to.
Your first problem will almost certainly be that the engine won't start because it has no way of knowing that the box is in park
Cruise control at least on Auto's apparently monitors selected gears to decide if Cruise mode is valid or not under the selected conditions.
Something else that it would be worth doing is to find out what the software part numbers are in the Engine , BSI and ABS ECU's for both mechanical and auto configurations if they are the same then it would indicate that there may not be such a big problem, if different then you would need to find out if you could get the code required to flash the ECU's having checked before hand that the ECU's are actually re-flashable.
Cachaciero
