Xantia Caliper Retaining Bolt
timber tailored
Unread post by timber tailored »
Hi Folks,
Just sheared one of the long retainer bolts for the rear disc pads. Anyone know where I can source one on line or know the size and the type of the bolt to do a search or is it a long treck to the nearest Citroen dealer.
Brian
HDI
x 7
Unread post by HDI »
Dealer only part I suspect.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
If you have sheared the bolt theres a DAMM GOOD chance the caliper is suffering the Alloys Corrosion, and is PUSHING the caliper to an angle, you can see this from the wear on the pads..
Shear or remove the other bolt, remove the caliper, remove all the crrosion from the calliper and arm mating face if any, then DRILL out the sheared parts, you CAN use a LONGER bolt and nut and put them RIGHT through to the other side of the mounting area, and then bolt it up together..
It sounds about M8? But if you drill it out you may have no thread left, so use a longer bolt and nut..
Paul
A very sad...
1994 XM 2.1 d auto
citroenxm
Fallen Hero
x 70
When you offer up the calliper put a layer of Grease of similar between the caliper and arm mounting face, to help prevent crrosion again
Paul
A very sad...
1994 XM 2.1 d auto
HDI
x 7
I think it's the pad retaining bolt being referred to , not a caliper retaining bolt. The pad bolt is a long M5 or M4 from memory , with a thread just at the very end.
Probably a good idea to check for the dreaded caliper to arm corrosion anyway. Even if it's not then it can be coated to prevent it happening.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
citroenxm
Fallen Hero
x 70
Doh! Never thought of that one! Thanks HDi....
Paul
A very sad...
1994 XM 2.1 d auto
Stempy
Unread post by Stempy »
There are kits on ebay which include two pins, two nuts and two of the metal shields for £6.99 I think.
Lexia ponce
