Dismembered the brakes on the Xantia today to discover the bolts holding the caliper to the hubare torx. I've got Torx screwdriver bits but these are much bigger.
Can you get sockets to fit these? The only torx bits i've got are for screwdrivers. What size are they?
TIA
Xantia Caliper Bolts
- x 1056
mbunting
tomsheppard
blueboy2001
Bought a full set of bits with a 1/2" drive from the local motor factors for £10, I'm sure they'll come in again.
Job finished now, had to drill out one of the disc mounting screws as some fool had rounded it off. I've also sorted the handbrake, replaced the broken mirror, fixed a rattle inside the passenger door got the central locking working again, and given it an oil change.
AndersDK
