Hi guys
I still have the problem with the clutch of the ZX, but its getting worse. When the clutch pedal is not pressed, there is a whirring noise coming from the gearbox side. The noise goes away if I pull out the clutch pedal a little bit.
The noise is worse when I press the pedal and after a while, the pedal gets very stiff and its harder to change gears.
I suspect that the cable is gone. What do you guys think?
clutch problem (SOLVED)
oscarloco
Oscar Lopez
'94 ZX 2.0 8v petrol (restoration to its former glory on its way after being neglected by stupid Ex)
ken newbold
- x 4
oscarloco
ken newbold
- x 4
- x 94
oscarloco
oscarloco
Well, sadly your prediction became true. The release bearing gave up and desintegrated plus 4 fingers broke- I had to replace bearing, pressure plate and clutch disk bringing the total token newbold wrote:It's probably seizing up and will end up burning it's way through the fingers on the clutch.
US$310!
But at least I can do really nice burnouts when I rev the engine to 4500 rpm and let out the clutch hehehe
Oscar Lopez
