normal coolant temperature ?
HDI
x 7
Unread post by HDI »
What is the normal temp gauge reading for a Xant HDI 110 ?
Mine runs a shade over 80 in normal use at motorway or A road cruising.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
Citroenmad
x 110
Unread post by Citroenmad »
Yep, thats the same for my C5 2.0HDi 110 and 206 2.0HDi 90. Sounds fine :)
Chris.
24 Toyota Yaris Hybrid
03 Seat Arosa 1.0S
Xantic
x 11
Unread post by Xantic »
Same here..
Jaguar 2.0 Diesel
Peugeot 407 Diesel
LIVING THE DREAM
Russ..
HDI
x 7
Thanks guys , would appear it has the correct thermostat then !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Sorry to put the cat amoungst the pegions, but Id think a shade over 80 would be too hot, all the 3 HDi Xantias here, AND the D turbos run between 70 and 80 on the guage, which I feel is more comfortable...
Id not be keen on anything a bit over the 80 - I realise it may be perfectly normal, but not for me..
Paul
A very sad...
1994 XM 2.1 d auto
HDI
x 7
Interesting !
I posted about the rad fans not appearing to cut in but there was a reply that the cut in temp is well over 90 !! I did think that was way too high !!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 1480
Mine runs a rock steady 80ish (needle just on the bottom of the 90 on the gauge), and has done ever since I got it. I think 70-80 is too low, caused by a leaky thermostat - both my Xantias TDs went like that as they approached 100k. Never bothered to change the stat mind.... The handbook says the temp might go up to 110 in 'normal' op - although their version of normal is probably towing 1.5te of caravan up the alps on a 40°C day!
citroenxm
Fallen Hero
x 70
Must say, at the temp mines runs at, NEW stat too, the heater in the car is MORE then hot enough!!!!
Im happy with it..
paul
A very sad...
1994 XM 2.1 d auto
HDI
x 7
RichardW wrote:Mine runs a rock steady 80ish (needle just on the bottom of the 90 on the gauge), and has done ever since I got it. I think 70-80 is too low, caused by a leaky thermostat - both my Xantias TDs went like that as they approached 100k. Never bothered to change the stat mind.... The handbook says the temp might go up to 110 in 'normal' op - although their version of normal is probably towing 1.5te of caravan up the alps on a 40°C day!
What model Xantia do u have ? Does it have the front undertray in place ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Citroenmad
x 110
80 or just a shade over is right for the HDis. Ive had three now and they all sit at roughtly the same.
Just had a new temp sensor on the 206 and thats now sitting just a shade above 80, where it was spot on 80 before.
They never get too hot though, my commute is usually in very heavy crawling traffic and they never budge above their normal running temp.
80-82 is fine for normal use.
03 Seat Arosa 1.0S
x 1480
HDi 110 - c/w undertray :P (I think I refitted it last time...!). Mine is only a poverty spec Forte so no oil temp gauge - but when I had a 1.9TD VSX with oil temp gauge, the oil (apparently) ran a lot cooler without the undertray fitted (I had to cut it off to change something, and never bothered refitting it). Xsara Picasso lost its tray after the last oil change - must get some new clips to get it back on to keep the oil temp up in the winter.
Xantidote
x 5
Unread post by Xantidote »
I don't expect our temperature gauges are going to be exactly the same, or perform with really great accuracy.
For me (albeit not an HDI), the important thing is when I see a change from the gauge's normal reading. Perhaps most importantly, we know what the gauge reads just as the fans cut in, and that tells us when it's getting hot! Then we want the gauge to tell us the temperature's coming back down.
Martin :)
Martin
1995 Xantia TDLX (deceased :( )
HDI
x 7
Agreed , I just needed an average temp reading from a few owners to determine what I should accept as normal. So just a needle width over 80 seems the norm so mines ok :)
The temp sender was duff until I recently replaced it and the readings were all over the place.
Now if a few people could say what temp they've noticed the fans cut in at I do the same for that :)
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
x 8298
RichardW wrote: HDi 110 - c/w undertray :P (I think I refitted it last time...!). Mine is only a poverty spec Forte so no oil temp gauge - but when I had a 1.9TD VSX with oil temp gauge, the oil (apparently) ran a lot cooler without the undertray fitted
I often wonder if this is one of the purposes of the undertray. My Activa takes ages to get it's oil temperature up and has no tray (did the Activa ever have one?) but the V6 warms its oil a lot faster but then there's no sump as such on that engine out in the full force of the breeze.
HDI
x 7
The undertray is part of the aero design and will definitely influence operating temps and warmup.
The main reason I want to find a replacement for mine , which is missing , is to keep road filth and salt out of the engine bay.
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
