IR Fob
KP
x 27
IR Fob
Unread post by KP »
Does anyone know if the microswitch bits for the IR fob are available from anywhere as my main one is begining to pack up and it doesn't look as if to be the solder joints for once and its not loose :(
I am also looking to get another fob as the rubber on mine is well worn and im not going to pay £100+ for a new fob from fleabay...
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
IR PLIPS were available from the stealers WITH INNERS for a massive ten quid!
Im sure I got a FULL plipper WITH inners for about 9 quid last year!!
And they are home programmable too!!
Paul
A very sad...
1994 XM 2.1 d auto
KP
x 27
Unread post by KP »
service citroen has them at well over £150 currently :(
the cheap bits are the blades and the kit to fit the blade as well, it costs an extra £5 for the key to come precut :)
citroenxm
Fallen Hero
x 70
:shock: :shock:
FOR an Infra Red one!!???? I should have bought a hand full of them then when I got mine for less then a tenner!!
Paul
A very sad...
1994 XM 2.1 d auto
HDI
x 7
Unread post by HDI »
Good grief , how much are the RF type ?? :shock:
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
KP
x 27
Unread post by KP »
depending on type its either
£81
£66
and there are two of the £81 type as it depends on the freq your car was set at...
If the rubber wears out though its £7 and part 9926FE to replace it which is a bit pricey for some rubber...
HDI
x 7
Prolly cost about £0.75 to make !!!
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
petercook44
Unread post by petercook44 »
Kp i have a spare fob with a decent rubber cover and i am nearby in Grimsby
fred1
Unread post by fred1 »
Are you sure its the switch and not the soldering of the LED that is causing the problem?
I used to have more problems with the LED soldering on my 370K Xant.
John
x 1459
Unread post by xantia_v6 »
It can also be that the IC chip needs resoldering (but you usually can't see the microscopic cracks in the solder). Best done with a hot air soldering iron, other techniques are available, but require some practice.
KP
x 27
Unread post by KP »
Definately the switch as it works intermittantly, the IR LED works just fine when you use the dead locking microswitch every single time and reckon its from the over use compared to the other switch.
Peter if the one on ebay falls through how much are you after for your spare one??
exect
Unread post by exect »
I bought a pack of switches from ebay and sucessfully repaired mine.
Regards
Exect
the_weaver
Unread post by the_weaver »
For electronic components in general try:-
Maplin
http://www.maplin.co.uk/
and
RS Components
http://uk.rs-online.com/web/
Paul
mark21td
Unread post by mark21td »
exect wrote:Hi,
Regards
Exect
Do you have the name of the seller ?
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
x 5672
I'm sure that RS and Farnell still only sell to the trade and you have to have a business account with them.
RS do however have Trade Counters (there is one a couple of miles from me) and if you go in when it is quiet and sweet talk the man, they will sometimes be persuaded to sell direct.
