LHM and O rings
Duracell
LHM and O rings
Unread post by Duracell »
I've just stripped my hydractive electrovalve and need a new O ring as the original is split. My main dealer can't help and although I've worked out what size I need, I have no idea about the compatability of the various o ring materials with LHM so trying to source one from a different source would be guesswork. Does anybody know what material would work?
x 5672
The LHM compatible material is known as Vitron.
Give Pleiades a ring, they may be able to help.
cachaciero
x 9
Unread post by cachaciero »
myglaren wrote:The LHM compatible material is known as Vitron.
Pretty sure that equates to Viton in English which is I believe a synthetic rubber type material widely used in it's liquid form for sealing aircraft fuel tanks. I am pretty sure I have seen Viton quoted as an O ring material in a catalog........ somewhere :-(.
Cachaciero
Duracell
Thanks both of you - Viton O rings appear to be commonly available so hopefully it will not be a problem
HDI
x 7
Unread post by HDI »
Viton will do it but as LHM is a mineral oil based fluid , nitrile O rings would be fine too.
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
steelcityuk
Unread post by steelcityuk »
I used one from a blister pack from the local car spares. As a test I dropped another in to a jar of LHM. 4 years later it's still good as new.
Steve.
not applicable
