weak interior fan ?
HDI
x 7
weak interior fan ?
Unread post by HDI »
Are interior ventilation blower fans weak on Xantia's ? The speed on mine seems fine , the auto setting seems to max it out from the sound of it but there isn't much force at the vents !
Compared to my Mitsubishi Evo , which is a standard Lancer trim and equipment wise , it's pathetic ! The Evo's fan will blow yer sunglasses off !!
Now using '00 Xantia LX HDI, pov spec :(
My past Citroens :-
'00 Xantia SX HDI, now dead due to accident :(
'99 Xantia HDI 110 Exclusive, RIP :(
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
'79 CX2400 Pallas (scrapped :( )
& a couple of Peugeots !
MikeT
x 232
Unread post by MikeT »
My guess is the pollen filter needs changing.
Sl4yer
Unread post by Sl4yer »
Mine doesn't have the most powerful fan on earth. I guess it's because demisting is supposed to be carried out in conjunction with air con (the air con engages with the slider in the demist position), rather than using brute force!
Now Citroenless for the first time in 20 years
2008 Mazda RX-8 231
2007 Honda CR-V Auto
HDI
x 7
MikeT wrote:My guess is the pollen filter needs changing.
Ok , I give in , where do I find that ?
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Xaccers
x 186
Unread post by Xaccers »
Under the passenger foot well, flop down the carpet and there is a rectangular panel about 2 inches wide or so.
It slides sideways, but I can't recall exactly in which direction.
Once you've managed to get it off, pull out the manky old filter and remember which way round it fits, then slot in the new one.
Might be worthwhile also using one of those aircon sanitiser sprays too as they're only around £10
DIY sphere tool
HDI
x 7
Cool , cheers ! Typical Frenchness :)
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
MikeT
x 232
You have a real aversion towards manuals and handbooks, don't you? :lol:
HDI
x 7
:D
I wasn't at home where the Paynes and owners manual's are.
TBH the Paynes manual is a waste of time anyway and if the pollen filter location is in the owners manual I'll chew a 21mm socket !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
MikeT
x 232
:lol:
scratcher
x 3
Xantia blower
Unread post by scratcher »
Hi, they can start to get a bit slow if the brushes
on the motor are getting worn. I have had to replace mine and my friends. You can get brushes from any small firm who "does up car electrical motors and dynamos", you will have to buy a slightly larger size and carefully sand them down to size until they fit. Should'nt cost more than £2. Worth a try! Gerry
Xantia vsx
GSA 1300
Previous AMI8 estate
GS1015
GSA1300 estate
BX16
BX17d
BX19destate
BX19d
HDI
x 7
Thats the thing though , the motor sounds fine , plenty of action but not much air from the vents.
Will have time tomorrow to check the pollen filter. Spose it could be blocked with leaves and stuff.
I just like to have a good blast of air when it gets warm outside and also for demisting , de-icing etc !
My past Citroens :-
'97 Xantia TD SX
'96 Xantia TD LX
'96 ZX TD
'89 BX TD
'88 AX GT
Xaccers
x 186
Slide the cover off allong the cover's length towards the driver's seat.
The pollen filter goes in with the pointy end towards the passenger front wheel, will find out tomorrow if the longer edge is towards the engine or not, totally forgot about that bit of info today when I was lending Jim a hand.
DIY sphere tool
Clogzz
x 40
Unread post by Clogzz »
Like this :mrgreen:
red_dwarfers
x 58
Unread post by red_dwarfers »
A tip, when you're trying to find how the pollen filter cover actually comes off, don't put your head in the passenger footwell for a better look, realise how it slides off then pull it off. I did and was covered with all this dust/flies etc... My filter was so clogged up that I genuinly thought the original colour was black.
The blower does work a LOT better now it can kick air through more easily!
Kev
'19 C4 Cactus 130 Flair
MikeT
x 232
:lol: @ Kev - great tip!!
But they are black aren't they?
