Xantia Radio Code
Chevron Terry
Xantia Radio Code
Unread post by Chevron Terry »
Hi ,
My Xantia Radio , When I switch it on , I get four lines and not the word "code ", so Iam unable to put in the code .
[ I have only just got the car ! ]
Any ideas ,
Many thanks
Terry .
Z.X. 1995 D [ 19905. ]
Xantia 1997 td .
KP
x 27
Unread post by KP »
You will need to leave it powered on for a god few hours i have found to get it to the stage where it allows you to put the code in :)
In xantias you can move the fuse over to allow it to be powered on without the key in the ignition though im not sure if its the same for a ZX.
Xaccers
x 188
Unread post by Xaccers »
Buttons 1 - 4 correspond to each line.
Press each button until the line turns to the number you want, so 1201 means press button until you get 1, 2 until you get 2, 3 until you get 0 and 4 until you get 1, then press 6 for enter.
DIY sphere tool
MikeT
x 232
Unread post by MikeT »
Assuming it's the same operation as mine; As long as you're not locked out, press and hold the BND button to get to the CODE input stage.
citroenxm
Fallen Hero
x 70
Unread post by citroenxm »
Clarions, in Series 2 cars, press and hold the BND button as per mike T says above, but series 1 cars, blaupunkt radios are leave on for a GOOD hour or so...
Paul
A very sad...
1994 XM 2.1 d auto
mark21td
Unread post by mark21td »
I don't have the code for mine and it's asking for it, can I get it from somewhere ?
It's a clarion BTW.
99 406 LX HDI 90 estate
99 C250TD sport estate
01 306 HDI 90 meridian estate
Brew my own biodiesel
http://www.shorewasteoil.xtreemhost.com/" onclick="window.open(this.href);return false;
MJM
Unread post by MJM »
I got my code from a dealer. One I approached wanted £15 for each code, radio, key and security. £45 :shock:
You may get the radio code with just a phone call.
I went to a different dealer, with the V5 for proof of ownership and was quoted £15 for the three. He gave me the radio code and said he would have to get the other 2 when Citroen opened on monday.
I said fine, could they phone them through?
No problem sir.
I'd better pay you now, then.
That's ok, have them on us. :D
Not all dealers are the same.
MJM
1999 Dante red Xantia Exclusive 2,0 petrol. No smelly diesel for me. Now re-homed
2007 Wicked Red C5 Exclusive. Now a smelly diesel automatic for me.
citroenxm
Fallen Hero
x 70
mark21td wrote:I don't have the code for mine and it's asking for it, can I get it from somewhere ?
It's a clarion BTW.
Depends which Clarion it is - Is it the Clarion from aSeries 2 car? With CD Changer control?? If so, then the CHIP that holds the code needs reading, which I can do...
Or, alternativly, spend about 20 quid from a dealer getting it read out...
Paul
A very sad...
1994 XM 2.1 d auto
